posted on 3/8/08 at 05:21 PM |
Chemical Metal
Stripped my chassis of all ali panels and will be having steel welded in - have to fill in the old rivet holes and can't really be arsed welding
each one up.
Are these 'chemical metal' products any use for this sort of thing, or should I just bite the bullet and weld 6,345,987 holes?
SeaBass
posted on 3/8/08 at 05:26 PM |
Why are you welding in steel panels?
[Edited on 3/8/08 by SeaBass]
StevieB
posted on 3/8/08 at 05:33 PM |
I've used chemical metal for non structural stuff before and it is quite good - just make sure you only mix up what you can use quickly as it
goes off quite quickly.
Curious as to why you;re welding in steel panels though - it'll add a hell of a lot of weight.
posted on 3/8/08 at 05:43 PM |
I knew when I posted this message that there would be more references to the steel panels aspect than the Q I asked
Been discussed elsewhere, but very briefly - by my rough calculation the steel will add another 13 kilos to the car... my engine will have (hopefully)
around 450 bhp, so I'm not too concerned about the weight!
The reason = I have stripped and re-furbished a number of cars with rivet panels, and I absolutely HATE drilling out rivets, trying to remove the
panels so gently that I can re-use them again, failing miserably in this endeavor, throwing stuff across the garage, cutting new panels, drilling them
to match the old one and then re-riveting them!
I also HATE having corroded chassis members (hence the reason I'm often stripping them and re-powdercoating them). A single steel structure
makes stripping a day job and re-assembly no more than a weekend work!
So, to put it bluntly... I'm a lazy b*stard!
minitici
posted on 3/8/08 at 05:51 PM |
Hope you have managed to get all the old rivet ends out of the tubes - they don't half rattle
posted on 3/8/08 at 06:51 PM |
Nope... couldn't be arsed with all the pallaver, so poked the little buggers through and squirted a dollop of waxoyl here and there.
posted on 3/8/08 at 07:07 PM |
If you can hear them over the wind noise you aren't going fast enough. If you weld the panels on over the holes you shouldn't need to fill
them in, just seal the join between the two.
jacko
posted on 3/8/08 at 08:26 PM |
Whats wrong with alloy and sikaflex
that's how buses are made very few rivets
posted on 4/8/08 at 10:28 AM |
Yep - had thought of that... but again, it involves too much labour (by my standards!) to strip when the time comes.
Mix
posted on 4/8/08 at 03:48 PM |
Hi
Whatever you use to seal the rivet holes will be subject to the heat of welding the steel panels and as such the only method I'd be confident
would retain it's integrity from the corrosion point of view would be welding. Even then I'm not sure how you would treat the interface
between the panels and box sections, (sealing fillets after welding?).
Regards Mick
posted on 4/8/08 at 04:21 PM |
Ah... good point, well made!
Think I'll cut the panels, so they stop just short of the rivet holes... the seam weld can perhaps deal with both at once?
