Author: Subject: making 26 mm dia. glass disc + looking for aluminium disc
posted on 13/1/09 at 10:33 AM Reply With Quote
firstly the "on the scrounge" bit.
I am looking for some 26 mm aluminium - else 1 inch or 25 mm diameter aluminium rod to make some 5 mm to 10 mm thick discs - anyone got some offcuts?
I also would like to make 26 mm diameter glass discs - is this possible without any specialist glass cutting tools? I am guess not.
NigeEss
posted on 13/1/09 at 10:49 AM Reply With Quote
I've got a bit of 5mm ali plate. How big a piece do you need ?
Can't help with the glass though.
Are you making a wind chime?
ReMan
posted on 13/1/09 at 10:52 AM Reply With Quote
Well I'm intreagued to know what you want them for, obviously nothing to do with the build?
The aluminuium ones should be easy enough to get lathed off a rod.
The glass will be harder, glass merchants use like a compass with a cutter on the end, but i think it would be presty tricky to cut that small?
Sorry not more help
mad4x4
posted on 13/1/09 at 10:54 AM Reply With Quote
Does it have to be Glass, Could you use polycarbonate
polycarbonate can be cut with a jigsaw and filed round on a belt sander.
Scot's do it better in Kilts.
posted on 13/1/09 at 10:56 AM Reply With Quote
1. piece big enough to get four 26 mm discs - say 60 x 60 allowing for saw cuts.
Since I do not have a lathe, I cannot see how I can make the surfaces flat hence rod may not be the way.
2. I would like to make a heat sink for my DIY LED lamps - so it fits inside a tube. The surface needs to be flat but the roundness is not so critical.
re: the glass - this is lens on the front; since I don't think I will be avble to make from glass or find something like that, I probably will have to use plastic/peerspex or similar.
NigeEss
posted on 13/1/09 at 11:02 AM Reply With Quote
U me your address and I'll pop some in the post. If I can work out how to hold a something
without a hole in the middle in the lathe then I'll make them for you too.
tegwin
posted on 13/1/09 at 11:12 AM Reply With Quote
Polycarbonate would be a far better choice than glass... lighter, tougher.....
www.verticalhorizonsmedia.tv
posted on 13/1/09 at 11:15 AM Reply With Quote
^^^ that sounds good - anyone know of source for polycarbonate sheet? (I should be able to cut that too!)
a CD case?
tegwin
posted on 13/1/09 at 11:27 AM Reply With Quote
CD cases are usually acrylic.... brital and sh1t
seeings as you dont need very big pieces...
Try ringing a few suppliers from google and see if they will send you a "sample" or two because you are thinking about placing a HUUUGE order
posted on 13/1/09 at 12:14 PM Reply With Quote
I'd make the outer disc out of polycarbonate. Pretty easy too. You just need to be able to drill out a disc without a central pilot drill hole.
Get two pieces of wood (10-20mm thick), use a hole cutter to drill a hole through it. Use a hole saw with an I/D the same as the O/D of the disc required. Take out the hole cutter central pilot drill bit. Clamp the two bits of wood together with the polycarbonate between. the hole in the wood will act as a guide for the hole cutter (hence no drill bit needed) and cut out the disc. Job done.
I've got some offcuts of polycarbonate in my garage. It's probably 3-4mm thick. Give me a shout if you want it. Not sure how easy it is to post (its a bit fragile in big sheets). Otherwise B+Q sell sheets of it.
One thing to know re polycarbonate when drilling is don't go too fast or it'll melt....
mad4x4
posted on 13/1/09 at 12:50 PM Reply With Quote
a CD case?
No but bus stop windows are made of polycarbonate....... as it is near vandal proof
trikerneil
posted on 13/1/09 at 01:29 PM Reply With Quote
NigeEss
I have machined brass sheet by sticking it to some plywood with wax then using a pressure pad to sandwich the sheet between a live tailstock centre and the chuck.
Neil
ACE Cafe - Just say No.
NigeEss
posted on 13/1/09 at 01:46 PM Reply With Quote
Neil,
that's near what I worked out. There's actually enough friction between the ali plate a
and a bar in the chuck to keep it clamped solid with a live centre.
O2GF74.
Got your U2U's and as it's easy that ^ way I'll turn them.
Nige
rf900rush
posted on 13/1/09 at 03:11 PM Reply With Quote
Hi
Not sure exactly what you are using your LED lamps for,
but I recently had to make up some lamps for my brother's bicycle.
see ohter post HERE
Soldered the LED's to a 'U' bent copper strip.
The lenses were from Farnell LINKY
Martin
posted on 13/1/09 at 03:26 PM Reply With Quote
yes - I've seen that.
I have 5 W lamps and the housing is getting up to 50 degree C - I am looking at fitting a bit more metal to act as a heat sink, not entirely convince it will make that much a difference - the worry is that the driver, that will sit inside the housing will not be happy.
I am hoping that when moving and also outside, the cooler air flow will be enough.
I have an idea to mount the emitter on a 25 mm solid aluminum rod, maybe that will be version 2.
rf900rush
posted on 13/1/09 at 03:36 PM Reply With Quote
Hi what driver are you using ?
I used a LM3404 from farnell Linky
Controlled by a Microchip microcontroller.
Not yet small enough to go in the lamp case yet.
All this is yet to be field test though.
If you want some simple machining done I may be able to help ( got a hobbly lathe etc), Just PM me.
Martin
PS
What about a small heatsink turned to 26mm.
[Edited on 13/1/09 by rf900rush]
posted on 13/1/09 at 03:41 PM Reply With Quote
I am not familar with that regulator but I am using 5 W driver board from ebay - these are postage stamp size.
<<--- linky
rf900rush
posted on 13/1/09 at 03:53 PM Reply With Quote
Your PCB seems to operate very simular to mine.
Should not get that hot.
posted on 13/1/09 at 03:54 PM Reply With Quote
it doesn't but it sits inside the lamp housing (= copper pipe) I've had a thermocouple in there an temp is 50 C.
Fred W B
posted on 13/1/09 at 08:55 PM Reply With Quote
Juts cut the ally heatsinks out of plate with a hole saw?
Fred W B
[Edited on 13/1/09 by Fred W B]
prelude1980
posted on 13/1/09 at 09:21 PM Reply With Quote
did you manage to get some polycarbonate discs in the end?
If not I can sort some out for you if you let me know the thickness of the disc
I work for a plastic fabrication company so have shed loads of the stuff, if its of any use
Speed has never killed anyone. Suddenly becoming stationary... that's what
gets you.
https://www.topcashback.co.uk/ref/dodd1980
