chrisspartan
| posted on 4/2/09 at 08:09 PM |
Can anyone recommend tube bending services in Manchester Warrington area??
As the post say can anyone recommend a tube bending services in Manchester/Warrington area??
I am struggling to get my 50mm OD 2mm wall thickness tube bent for my rollcage - any recommendations would be greatfully received.
Chris
[Edited on 4/2/09 by chrisspartan]
welderman
| posted on 4/2/09 at 08:32 PM |
can do 48.3 if that helps, not got a former for 50mm.
check out my photo archive( kastrato), i can do bending
[Edited on 4/2/09 by welderman]
Thank's, Joe
I don't stalk people
Mal
| posted on 4/2/09 at 08:35 PM |
Try J P Exhausts in Macclesfield
Tel 01625 619916
web jpexhausts.co.uk
chrisspartan
| posted on 5/2/09 at 01:01 PM |
Joe, I assume from the size of your former you have a hydraulic pipe bender.
I have been told that with the tubing I have (CDS 360 Hydraulic tubing) I will struggle to bend it with a pipe bender.
Your bends look spot on though.
Is it a hydraulic pipe bender that you have? - if so did you pack the pipe with sand and what material was your tube/pipe?
Chris
