| posted on 20/2/09 at 08:20 AM |
DIY carb balancer tool
For bike carbs - was wondereing whether it is worth having a go making a set using MAP sensors - anyone tried this?
Or know if thius has been done? lunky? info?
r1_pete
| posted on 20/2/09 at 08:31 AM |
I wouldn't bother, for less than £50 you can buy a set
Link
whitestu
| posted on 20/2/09 at 08:40 AM |
Don't buy those they're rubbish!
Spend a bit extra and get something that works like these.
Morgan
I already had a set of morgantunes for a twin and thought I'd save a few quid when balancing the 4 carbs on my Indy by buying the gauge type.
They are utterly crap and are still sitting on my shelf unused after the first couple of attempts to use them. They're about as accurate as
listening to the carbs. I'd have binned them but it seems a waste of money!
I bought a set of 4 Morgan tune balancers for £50-60 and they are just miles better.
Stu
r1_pete
| posted on 20/2/09 at 09:11 AM |
Never had a problem with them, and have checked them by balancing the carbs then swapping the pipes.
Have lost a couple of the restricter valves, so if you want to flog me your gauges, I have a use for them..
whitestu
| posted on 20/2/09 at 09:25 AM |
Maybe there are different levels of quality out there - the ones I got seemed pretty poor. Which of the restrictors do you need?
stu
thunderace
| posted on 20/2/09 at 09:28 AM |
this is the cheep way and it wors the same as the dear one ,mine cost me £6 on ebay
http://cgi.ebay.co.uk/Gunson-Carbalancer-G4053-Air-flow-balancer-As-new_W0QQitemZ190288049175QQcmdZViewItemQQptZUK_Diagnostic_Tools_Equipment?hash=ite
m190288049175&_trksid=p3286.c0.m14&_trkparms=66%3A2%7C65%3A1%7C39%3A1%7C240%3A1318
whitestu
| posted on 20/2/09 at 09:33 AM |
I've used one of those as well and IMHO the Morgantune set is well worth the extra.
Stu
mark chandler
| posted on 20/2/09 at 11:00 AM |
Whats wrong with pipe and ball bearings?
Have a search, plenty of solutions for pennies, you are not measuring pressure (or lack of it) just difference, if ball bearings scare you then water
in the tube.
thunderace
| posted on 20/2/09 at 11:59 AM |
you can do it whit a bath plug and a6mm id clear hose and some water and food coulouring it works and cost about 50p to make.
i tested it against my kawasaki one that cost £150 as was just as good.
took about 5 mins to make .
was going to sell them on ebay lol
dinosaurjuice
| posted on 20/2/09 at 12:27 PM |
^^^^ yep - balanced a cx500 engine with this method. worked a treat.
[Edited on 20/2/09 by dinosaurjuice]
trikerneil
| posted on 20/2/09 at 01:25 PM |
Bin there - done that - coz I culd.
LINKY to the world's most expensive vac gauges
Neil
ETA If anyone wants to give my setup a try U2U me.
[Edited on 20/2/09 by trikerneil]
ACE Cafe - Just say No.
| posted on 20/2/09 at 02:37 PM |
Simplest balancing tool is four lengths of aquarium pipe with some coloured dies. Jobs a good'un.
Otherwise the Carbtune is quite a nice bit of kit. MAP sensors are awfully expensive. You don't need an actual value after all, just to make
sure they are balanced....
| posted on 20/2/09 at 02:41 PM |
reason for asking is that I have one ot two map sensors; wiring them up should not be that difficult; using DVM to read pressue would be all that I
need.
