blakep82
| posted on 26/6/09 at 10:40 AM |
what do you use to cut hose
stainless braided hose that is. need a nice clean end on the braid, i can't think of a good way to do it that doesn't leave a messy end on
it
________________________
omega0684
| posted on 26/6/09 at 10:44 AM |
wrap the section you want to cut in loom tape to stop it from fraying and then use an angle grinder
blakep82
| posted on 26/6/09 at 10:46 AM |
ah good call! suppose any kind of tape will do? electric tape, duct tape?
DarrenW
| posted on 26/6/09 at 10:49 AM |
I wrapped mine with electrical tape then cut with hacksaw.
blakep82
| posted on 26/6/09 at 10:54 AM |
i'd have thought the starnds would get stuck between the teeth, but i guess if i've got fine tooth blades, its another good option!
omega0684
| posted on 26/6/09 at 10:55 AM |
do you have a bench cutter with a metal cutting blade, that will give you a nice straight cut.
spdpug98
| posted on 26/6/09 at 10:56 AM |
^^^^ I do exactly the same ^^^^
My Blog: http://spdpug98.wordpress.com/
Richard Quinn
As above but using a HD cut off wheel in a dremelesque tool
MakeEverything
| posted on 26/6/09 at 11:41 AM |
I use a ratchet pipe cutter.
Kindest Regards,
Richard.
AdamR
| posted on 26/6/09 at 11:43 AM |
Dremel for me. Works a treat.
posted on 26/6/09 at 11:56 AM |
wrap with tape and then a dremel cutting disc.
only need to do the metal braid though as the rubber hose smells when heated.
you can buy rubber end caps - fit 6 and 8 mm hose to put over the ends - stops the metal strands getting into your fingers when pushing hoses on - no
need to ask how I found that out
but the end caps can be hard to fit. So cut a piece of thin but stiff plastic, such as a pop bottle and make into funnel shape. insert funnel into
end cap and then you can push the hose in - metal strands will not catch in the soft rubber, then pull out the plastic. sorted.
irvined
| posted on 26/6/09 at 12:06 PM |
Duck tape and dremel for me as well.
http://irvined.blogspot.com
andkilde
| posted on 26/6/09 at 12:33 PM |
I've heard old school guys use a cold chisel with a beefy piece of steel backing it up -- I can see this working on -3 brake-line sized stuff,
but being pretty sketchy for larger tube.
I've done the masking tape and a cutoff wheel for an oil-cooler install, worked a treat.
t
blakep82
| posted on 26/6/09 at 02:20 PM |
might just go with the grinder. go through the whole lot. think the speed of the disc will help stop and threads of stainless steel picking out.
if i was doing loads i'd think about one of those ratchet thingys. but not for 3 cuts or so
| posted on 26/6/09 at 03:13 PM |
Problem with the grinder if you cut through the entire pipe is you get a load of rubber dust in the pipe.
blakep82
| posted on 26/6/09 at 03:14 PM |
^ thats true, could always blow most of it out with compressed air, and a fuel fliter to catch the rest
oadamo
| posted on 26/6/09 at 04:49 PM |
i find some sheet cutters are the best make sure you have a good sharp pair tho. you get a nice cut and the wire stays nice and straight.
adam
