Author: Subject: Tube angle paper pattern maker
Russell
posted on 19/10/09 at 06:30 PM Reply With Quote
Apologies if this has been posted before but I found a natty little free program here:
http://www.ytcn.nl/archief/index.php?dir=Software/cone_calculator_1.3/
It allows you to print accurate paper templates to cut out and wrap round tubes for cutting at the correct angle (for those of us without accurate chop saws). It's different to the tube mitre program because the tube ends it produces are a flat plane. I'm tinkering with it to produce a series of short tubes to join up to make a bike carb manifold. You can even preview the results in moveable 3D.
Edit to say.. I've been browsing the rest of the site and if you're into older Yamaha bikes (RDs in particular) you really should go there. I just got a exploded view of my Fazer Mikuni carbs.
Russ
[Edited on 19/10/09 by Russell]
I'm a bilingual illiterate. I can't read in two languages.
eccsmk
posted on 19/10/09 at 10:25 PM Reply With Quote
it tells me i need to register/login
doh !
dave r
posted on 20/10/09 at 05:45 AM Reply With Quote
it does me as well, but the file you want is above the log in box at the top
designer
posted on 20/10/09 at 06:56 AM Reply With Quote
Isn't tube mitre the better programme for fiah mouth ends?
eccsmk
posted on 20/10/09 at 03:39 PM Reply With Quote
well spotted
god im stupid sometimes
