Author: Subject: thin cutting discs
blakep82
posted on 30/4/10 at 11:26 AM Reply With Quote
thin cutting discs
you know, the 1mm thick ones, are they ok for aluminium?
[Edited on 30/4/10 by blakep82]
________________________
Lightning
posted on 30/4/10 at 11:27 AM Reply With Quote
probably not but i have used them
liam.mccaffrey
posted on 30/4/10 at 11:28 AM Reply With Quote
last time i bought (4 years ago) i got separate ali slotting discs.
Build Blog
Build Photo Album
posted on 30/4/10 at 11:29 AM Reply With Quote
For ali you do need special discs the standard ones get gunked up in no time at all!
mangogrooveworkshop
No you should not use a cutting disc on ali.
Better to use a jigsaw with oil lube to do cuts .
The carborundum discs can and will explode showering you with shrapnel....
Been there done that not very nice
blakep82
posted on 30/4/10 at 11:35 AM Reply With Quote
cool, thanks lads
started cutting some tube with one last night, and before i even got through the wall decided it was probably a bad idea. but seeing as they're so thin and light, i didn't know if they'd be ok
boggle
posted on 30/4/10 at 11:44 AM Reply With Quote
they do explode and hurt.....
but i use them
hacksaw may be better...
u2u me for details
blakep82
posted on 30/4/10 at 11:45 AM Reply With Quote
yeah, i changed to hacksaw, but i never seem to be able to cut straight
tony-devon
posted on 30/4/10 at 11:56 AM Reply With Quote
as they say, no they will snatch/let go and its not pleasant
if you doing a few the same size, try and fine a bit of steel tube thats a nice sliding fit over the one your wanting to cut, just a short bit, with a jubilee clip at the end your not cutting, this holds it in place, then just run the hacksaw down against the steel tube end
simples
heavy is good, heavy is reliable, and if it breaks, hit them with it
Stott
posted on 30/4/10 at 11:57 AM Reply With Quote
I get these from the staff shop in work (bosch) and have used them a few times on ali and they were good:
Discs
Simon
posted on 30/4/10 at 04:03 PM Reply With Quote
I've never had probs cutting ally with them. Put some tallow on the ally - if nothing else, it makes it smell nice
Just make sure you have proper saftey gear on - not t shirt and shorts!
Simon
iank
posted on 30/4/10 at 04:28 PM Reply With Quote
Do you have a good quality (heavy) frame and decent bi-metal blades? I always had trouble until I spent money on good blades.
Anonymous
ernie
screwfix erbauer 45203, 115 x 1mm
40inches
posted on 1/5/10 at 09:40 AM Reply With Quote
cool, thanks lads
I use a plumbers pipe cutter, cuts through 1.5mm steel tube, if you take it slow, like this one or the same thing made for cutting exhaust pipes
