posted on 24/2/11 at 12:29 PM |
fitting a bush
ive got the bush in the freezer, the wishbone de-rusted and lubed with a touch of copper grease, and the blowtorch ready. Have i missed anything? The
grease is just to help it in, not because i want to restart the crushtube debate!
ReMan
posted on 24/2/11 at 12:50 PM |
Edges of hole deburred
The vice, to press it in with
Beer
www.plusnine.co.uk
RichardK
posted on 24/2/11 at 12:51 PM |
Nope, thats about all you need! you got the bush in a plaggy bag? didn't even use a torch although I did make a sleeve (same stuff as the wish
bone although with a bit of material out so the bush didnt stick inside that!) and then a bit of solid rod or a socket set drive to ram it down, the
problem I had was it mushrooming when forcing it in, the sleeve stopped that.
R
[Edited on 24/2/11 by RichardK]
Gallery updated 11/01/2011
big-vee-twin
posted on 24/2/11 at 12:52 PM |
Try it without the grease first as the body of the bush should twist not swivel inside the wishbone. If its a poly bush and you really need to use it,
use grease that hasn't got petrol or derivatives in it as it attacks the material - use moly
http://www.triangleltd.com
Richard Quinn
posted on 24/2/11 at 01:25 PM |
Snicker, snicker, titter, phnahhh! Just me then?
posted on 24/2/11 at 02:01 PM |
ive had to stop for a break
Its the rear bush on the jeep and blooming enormous. And its tighter than i thought possible! Im currently using a g clamp and the mallet, and its
bloody slow! Would have been easier to get it off and have it pressed in but there are bolts i cant get undone. Might replace the g clamp with a bolt
through the packers now i think about it!
Cheers for the help, appreciated.
blakep82
posted on 24/2/11 at 02:40 PM |
long bolt though the bush, and the tube, steel plates for the bolt to go through, and impact wrnech? sort of like a vice?
________________________
posted on 24/2/11 at 02:59 PM |
just done that, worked well til about 10mm left to go, and then its stripped the threads off. Bugger!
posted on 24/2/11 at 04:59 PM |
ive now got it in a 30kgs vice, hitting the handle with a lump hammer, and its still not going the last bit! Is this excessive force?! Might have to
take it to get properly pushed in tomorrow
posted on 24/2/11 at 09:26 PM |
done, in 11 hours! I've just remembered why i normally take it to a garage!
