silverback
posted on 16/3/13 at 09:46 PM |
torx socket
Hi, just looked at my pinto head and the bolts are a torx socket fitting, does anyone know what size I need.
Thanx
Mick
adithorp
posted on 16/3/13 at 10:12 PM |
Are you sure they're a torq? I thought they were splined.
http://jpsc.org.uk/forum/
Dingz
posted on 16/3/13 at 11:54 PM |
T 55 I think?
went on and on.
jollygreengiant
posted on 17/3/13 at 12:58 AM |
If memory serves, the later ones were torx headed to identify them as allegedly stretch bolts, so check the lengths when out and clean. BUT I could be
wrong.
posted on 17/3/13 at 07:50 AM |
IIRC the early ones were splined and not stretch bolts, allegedly safe to reuse.
The later bolts were Torx and stretch so need replacing, T55 sounds the right size. Note the tightening sequence, which calls for something like
torquing down in stages then another 90 deg after that.
Haynes manual has all the info.
Mikef
posted on 17/3/13 at 08:13 AM |
Agree T55. I would suggest that if you need to buy one you get a one piece Impact one. They need a lot of grunt and the std ones I think are really
not up to it. This is the one I have, and been no probs.
T55 Torx Bit Socket 1/2 Drive FRANKLIN TOOLS TIS55 Impact Professional Quality | eBay
silverback
posted on 17/3/13 at 09:31 AM |
Thanx guys for info.
I will get new head bolts to be on the safe side.
I bought mine from the local spares shop for the Pinto head bolts and they had replacement bolts at about £1 each as well. The kit was a couple of
sockets for head and tensioner bolts and it did the job.
Mikef
posted on 17/3/13 at 10:02 AM |
Would defn go for the new bolts ,not sure what you are using it for but I use the Reinz ones with their head gasket.Good quality and not silly
prices. Get mine for Matt Lewis.
adithorp
posted on 17/3/13 at 10:19 AM |
wrong.
My mistake. It's a long time since I worked on one.
carlknight1982
posted on 17/3/13 at 11:03 AM |
Eat your wheaterbix first you'll need it for the last 90 degrees
Logic will get you from a A to B
Imagination will take you everywhere.
posted on 17/3/13 at 11:30 AM |
That so called stretch bolts need replacing every time is a fallacy.
They do deform into the lower endof the plastic range but this doesn’t weaken the bolts in fact it actually increases the elastic limit of the
bolt and dosen't effect the UTS of the bolt. Provided the bolts have not been grossly over tightened they will survive several tightening
cycles without causing any concern.
40inches
posted on 17/3/13 at 11:39 AM |
What BT said. SAAB recommend a slackening and retightening cycle to stop/prevent oil leaking from the cylinder head.
silverback
posted on 17/3/13 at 07:19 PM |
Thanx again lads. I knew this site was brill. Loaded with good advice.
