FASTdan
posted on 25/4/13 at 09:13 AM |
Who manufactures these Carb Balancers?
Can anyone tell me who the manufacturer of this type of carb balancer is?
carb balancer
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
theprisioner
posted on 25/4/13 at 10:10 AM |
My documentation says a company in Germany STE
see: http://vwparts.aircooled.net/Snail-Type-Syncrometer-Carb-Sync-Tool-GERMAN-SK-p/ste-sk.htm
They are brilliant!
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
FASTdan
posted on 27/4/13 at 07:47 AM |
Thanks for that - bit of an elusive company, cant seem to find any info on them?!
baz-R
posted on 28/5/13 at 06:17 PM |
not the same thing but morgan carbtunes are great and best vac type ballancers i have used (link is airflow type)
i have a set from serviceing my bikes but set my throttle bodys a dream all you need is a vac point in each port or runner
you can also buy brass metric tails to fit into manifold or use plastic adapters and just plug up holes with a bolt
i can also point out with vac gauges you can see all cyl readings at the same time and will only take 15mins max to dial in on a warm engine
