Author: Subject: Glueing a Magnet to propshaft
Mikey G
posted on 11/11/04 at 10:21 PM Reply With Quote
I have an Spa speedo and i have lost the magnet which was attached to the propshaft. Now i didnt fit the original but how would you do it? i have a replacement but would like opinions on how every one else has attached a magnet. was thinking Araldite may be good? but what else is out there as i'm unfamilier with adhesives.
Mike
Mr G
posted on 11/11/04 at 10:32 PM Reply With Quote
PU adhesive - polyurethane based available from builders merchants etc (approx £6) Has a number of trade names like 'sikaflex'
Fantastic product that has numerous uses while building your kit.
Araldite didnt work with our prop magnets (all 18)
HTH
G
Mark Allanson
posted on 11/11/04 at 11:04 PM Reply With Quote
JB Weld is always a good bet
posted on 11/11/04 at 11:06 PM Reply With Quote
Good old JB Weld 2 part adhesive. It works like Araldite, you mix it and sticks it and it takes abut 24 hours to reach full strength.
Mikey G
posted on 12/11/04 at 12:36 AM Reply With Quote
JB weld it is then
Ta
Jumpy Guy
posted on 12/11/04 at 09:23 AM Reply With Quote
just a quick hijack- where is the best place to glue them?
got a motorbike dash & speedo to fit
posted on 12/11/04 at 09:30 AM Reply With Quote
As near to or on the joints at the end of the prop. You won't upset the balance there.
Spyderman
posted on 12/11/04 at 09:06 PM Reply With Quote
Another simple way would be with the good old cable ties!
Or even belt and braces, glue and tie!
Spyderman
wilkingj
posted on 13/11/04 at 03:21 PM Reply With Quote
Anyone tried hot melt glue shrink down sleeves, ie shrink down sleeve with HMG on the inside.. it would never move then.
Best Regards
Geoff
http://www.v8viento.co.uk
givemethebighammer
posted on 14/11/04 at 08:13 PM Reply With Quote
I used super steel epoxy and a large tie wrap, but mine are round the drive shaft flange. I thought I wouldn't unbalance this bit by adding stuff to it.
