StevieB
posted on 29/6/14 at 08:18 PM |
Anyone do or know where to get some water jetting done?
Pretty much as per the title really - I'm looking for somewhere I can get something water jetted or maybe laser cut if anyone on here does this
or knows of a good place to use?
I need to make a couple of heat shields for the exhaust on my motorbike, looking for something along the lines of the touratech type things but they
don't do anything specific for my bike so figured I could get some knocked up.
I've burned through 2 sets of trousers to date. The factory shield is useless (snapped off long ago) and the after market bolt on items are a
bit short, plus there are two areas I need to cover. Probably looking at something like 2mm Ali.
I might also consider getting some anodizing done as well to give a good finish and make it look a bit 'factory' so again, any leads on
sources to get this done would be appreciated.
matty h
posted on 29/6/14 at 08:47 PM |
Maybe a bit far for you.
http://www.locatesupplies.co.uk/
Matty
leon51274
posted on 29/6/14 at 09:35 PM |
Yorkshire profiles are on my estate at Hessay, 01904 737095. Will be cheaper if you can do your own dxf or dwg, if your struggling and its a
basic-ish drawing then I could try and help. I'm in unit 5c.
Leon
