andyharding
posted on 8/3/05 at 11:29 AM |
Welding Chrome: Is it safe?
I need a couple of UJs for a gear lever extension I'm working on and 3/8 drive socket UJs seem pretty cheap. The problem is they all seem to be
chromed. Will it kill me if I weld a rod to each end?
flak monkey
posted on 8/3/05 at 11:38 AM |
No...welding chrome plated stuff isnt going to kill you if you only do a little bit. If you were doing it all day every day then you should
worry...
Just think stainless steel is about 12% chrome content...and most people would weld that happily enough.
Sera
http://www.motosera.com
Spyderman
posted on 8/3/05 at 11:56 AM |
Shouldn't be a problem welding chrome, but wouldn't it be easier to pin it instead?
A small nut and bolt going through would be a lot more user friendly.
Terry
Spyderman
posted on 8/3/05 at 01:29 PM |
You will end up with a brittle weld, brazing would be better.
simonH
posted on 8/3/05 at 02:18 PM |
Grinder ?
or gind off the surface layer to expose the steel underneath and weld to that
Never be afraid to try something new. Remember that a lone amateur built the Ark. A large group of professionals built the Titanic.
andyharding
posted on 8/3/05 at 05:24 PM |
Thanks guys.
Danozeman
posted on 8/3/05 at 06:26 PM |
Sockets etc are made of crap metal for welding. Brazing (which i HATE) is much better.. YOul find amig weld will soon break off..
Dan
gazza285
posted on 8/3/05 at 08:39 PM |
Once welded a piece of 1" nominal bore galvanised steam pipe to a 27mm socket for use as a wheel brace for a twin wheel Transit. Welded it using
low hydrogen rods and it gave years of faithful service, including the fat apprentice jumping on it not having realised that the nearside nuts were
left handed. Doubt it'll mig any good though, even if you grind the chrome off first.
Mark Allanson
posted on 8/3/05 at 08:49 PM |
How much stress is on a gearlever extension? If the UJ is chrome moly, try arc welding it with a 1.6mm stainless rod. I cannot see any problems.
