Author: Subject: Ramps - how do you stop them moving?
Just
posted on 29/7/06 at 08:58 AM Reply With Quote
Got some ramps off ebay and I am trying to get the Tiger up at the back. Even with some rubber mats under them, the ramps just keep moving backwards when I try and go up them. I can get about half-way up before they slide. Do I just need to approach them with a bit more speed or do I need a couple of daring assistants to take the strain?
Johnmor
posted on 29/7/06 at 09:03 AM Reply With Quote
Ramps
I had the same problem, I glued a strip of rubber along the base of the ramps, with Evostick, took 5mins and it cured it instantly.
Krismc
posted on 29/7/06 at 09:22 AM Reply With Quote
or a block of wood at the back of the ramps- up to the wall or sumthing!!
RichieW
Another trick is to get a piece of old carpet and stitch it round in a loop around the bottom rung of each ramp. Very locost.
Once the wheel are driven onto the carpet the ramps are stuck and cant move backwards as everythings is attached.
[Edited on 29/7/06 by RichieW]
bug1
posted on 29/7/06 at 09:52 AM Reply With Quote
I have drilled two holes at the back on the edge that is on the ground then screwed the to the floor then it will not move.
Danozeman
posted on 29/7/06 at 10:11 AM Reply With Quote
i welded som grips on the bottom of mine and turned the rear corners down into the ground so they dig in when they start to go. works perfect except on my gravel drive.
Dan
Just
posted on 29/7/06 at 11:02 AM Reply With Quote
Thanks all, two long pieces of wood to the back garage wall has worked a treat - car up, prop off, rear oil seal not moving......
graememk
posted on 29/7/06 at 11:18 AM Reply With Quote
i got my dad and brother to stand behind them..very brave
Aboardman
posted on 29/7/06 at 01:54 PM Reply With Quote
jack up the car and then push the ramps under the wheels.
trextr7monkey
posted on 2/8/06 at 10:44 PM Reply With Quote
Yeah ,
Captain Cunning's tip of the day, we do this with 2 sets of ramps facing inwards so car can't roll, cheaper than a post lift and so much room under there
