Author: Subject: bending 5mm flat bar
locoboy
posted on 21/7/07 at 12:31 PM Reply With Quote
I have just tried to bend my front wing stays that are made of 5mm flat bar.
Put it in the vice and heated it till it was cherry red.
Then bent it by hand whilst hammering the bend to help keep it tight.
Once cooled i noticed it had cracked on the outside of the bend and i have it a wiggle and i heard another 'crack' and the bend has as good as cracked through now.
How are you 'supposed' to do this in order not to crack it?
I have oly sone one wing stay so i need advice before i start on the other one!
Locoboy
tks
posted on 21/7/07 at 12:34 PM Reply With Quote
what i did was giveing it a deep cut with the angle grinder. (cut disc 1mm) then i just flipped it over and i tested the angles.
when i thought it was good then i just filled the cut up with weld. if i was you i would just do the second the same.
and then take it to a TIG welder.
He then can genereate a nice welding pool over/on the cracks. then its rock solid again.
Tks
posted on 21/7/07 at 12:38 PM Reply With Quote
Bend it to the angle you want and weld the crack up, it should last ages.
posted on 21/7/07 at 12:40 PM Reply With Quote
i tend to just hammer it cold in a vice.
worX
posted on 21/7/07 at 12:45 PM Reply With Quote
I'd do it cold aswell...
posted on 21/7/07 at 01:32 PM Reply With Quote
Depends how red your cherry's are...
I tend to heat it up until bright red (tomato red) then bend it. The steel should not have cracked if you did this correctly.
Heating to bright red will enable plastic deformation, but as stated they can be bent cold. Sounds like you may have a dodgy steel or left it to cool to much whilst braying it.
Steel doesn't typically like to be bent to too tight a corner either... any chance of seeing pictures. Occasioannly you get stress marks but not cracks...
Humbug
posted on 21/7/07 at 01:45 PM Reply With Quote
I did mine cold in a vice... bloody hard work, too!
posted on 21/7/07 at 02:01 PM Reply With Quote
Yup. Cold in a vice. No cracking......
locoboy
posted on 21/7/07 at 02:13 PM Reply With Quote
well i cut the cracks out with the grinder and filled it with weld so fingers crossed!
Colin
Locoboy
locoboy
posted on 21/7/07 at 03:50 PM Reply With Quote
Well on the second one i sliced tha back of it and heated it up more than before...................
expecting a nice easy tight bend it bloody snapped off!
So i had to weld it back on in the end anyway!
not having a good day at it today.
Think i may have fcuked up my front cycle wings to boot.
Locoboy
posted on 21/7/07 at 05:43 PM Reply With Quote
I took mine up to "as hot as I could manage with a torch in a makeshift hearth" - past yellow, heading for white. Bent like putty (hardly any need for a hammer) and no signs of cracking.
Blacksmiths would regard cherry red as "too cool to hammer, time to put it back in the hearth.".
Also - what kind of steel are you trying to bend? The BDMS (bright drawn mild steel - the shiny stuff) is likely to crack when bent. The hot-rolled "black" steel (with the scale) is far more malleable.
[Edited on 21/7/07 by David Jenkins]
