paulmw
posted on 4/8/07 at 11:39 AM |
Engine Sprocket
Tried everything to get the bloody sprocket off my ZX10r. I have just come back from ATS who couldnt budge it with their air gun.
Am I doing something wrong?. Ive put it into gear, bent back the washer. Is not a left handed thread is it
Any help my next resort is a lump hammer!!!!
MkIndy7
posted on 4/8/07 at 11:47 AM |
Can't help you with which direction to turn it but I can reccomend a product!
I think it was Loctite.. its basically a freezing spray, to try and works on the same principle as heating it up, only its much more controled and
doesn't damage/melt other surrounding things/
I'm sure i've seen it in Halfords for not sill money £4 maybe, in situations like or where you can't use heat, its probably worth
the investment.
I used it to get the Crank end bolt off a Vauxhall XE engine and that was something stupid like 250NM + 90 deg! and like you've said an
air-rench wouldn't toutch it!
indykid
posted on 4/8/07 at 11:59 AM |
if it's not turning the engine, try finding somewhere that does commercial stuff with a 3/4" or 1" drive impact wrench.
to get the crank pulley bolt out of a supra 7mge engine, we ended up using an inch drive air impact wrench at evening classes. i'd broken a
1/2" breaker bar and a truck size torque wrench trying to get it off prior to that.
the big impact wrench had it free in seconds
good luck and hth
tom
