Author: Subject: bending 19mm tube
davie h
posted on 24/9/07 at 08:38 PM Reply With Quote
bending 19mm tube
help
i am at the point of bending the rear panel supports RP1 and RP2 on my haynes roadster chassis i have tried the locost way but it didnt work. i have been looking for a pipe bender but can only find 15 and 22mm benders will these do the job???? or does it have to be 19mm
or is there anyone up here(Glasgow) that can assist for beer tokens
cheers Davie
goodguydrew
posted on 24/9/07 at 08:54 PM Reply With Quote
Hi there, life is a funny thing. I just did that job yesterday using my 20mm bender. You can borrow it if you want.
I live in Motherwell.
Andrew
omega 24 v6
posted on 24/9/07 at 08:58 PM Reply With Quote
Any sparkies will have a 20mm bender try an industrial building site I'm sure they'd do it at tea break for you.
davie h
posted on 24/9/07 at 09:03 PM Reply With Quote
goodguydrew u2u sent
thanks Davie
mark chandler
posted on 24/9/07 at 09:35 PM Reply With Quote
I cheated and cut up an old school chair !
Two nicely formed bends for free.
jkarran
posted on 24/9/07 at 10:33 PM Reply With Quote
You can wrap the pipe tightly in paper and tape up to the bender dia you're using/have, I did that with my cooling pipes and it worked a charm.
jk
scoop
posted on 25/9/07 at 01:36 AM Reply With Quote
I just filled mine with sand, used a bit of heat and slowly bent it round. The hardest bit is making them the same
James
posted on 25/9/07 at 10:12 AM Reply With Quote
I just bashed mine around the rounded bit of my bench vice!
