Author: Subject: chunky clamp for use with MIG welder
posted on 28/9/07 at 02:05 PM Reply With Quote
ok, so the clamps supplied with Clarke welders are pretty poxy - I can feel the handle get warm where the wires are crimped (the crimp is fine) so who sells a chunkier clamp ?
r1_pete
posted on 28/9/07 at 02:28 PM Reply With Quote
I bought one of these, works fine up to 180 AMP on my Cebora set...
http://cgi.ebay.co.uk/Welding-Earth-Clamp-200-Amp-Crocodile-Type_W0QQitemZ150127373469QQihZ005QQcategoryZ11774QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
thomas4age
posted on 28/9/07 at 02:29 PM Reply With Quote
Probably Halfrauds they have a very nice jumplead robust clamp over here in holland.
edit: pete beat me to it, that's the One very cheap also
Grtz Thomas
[Edited on 28/9/07 by thomas4age]
If Lucas made guns, Wars wouldn't start either.
posted on 28/9/07 at 02:47 PM Reply With Quote
yeah, should have looked on ebay.
so how do you attach wire to it? looks like the bolt should hold wire to clamp but the wahsers look quite small - unless the is a crimp connector you are menat to fit onto the wire.
I wonder if I can tonk up something similar at home with some old copper pipe......?
designer
posted on 28/9/07 at 03:26 PM Reply With Quote
Go to the local tool merchants; not Ebay.
These things are dirt cheap and one should always check them first, and you will get a more compact one which will still be able to carry the current..
The cheap ones on Ebay are too tight and take two hands to open!!
posted on 28/9/07 at 03:30 PM Reply With Quote
I got mine from the local BOC shop - not expensive, and come in various sizes.
thomas4age
posted on 28/9/07 at 03:51 PM Reply With Quote
and ask them to crimp on a decent AMP M8 sock on the wire at the same time.
grtz Thomas
RichardK
posted on 28/9/07 at 04:45 PM Reply With Quote
cheap mole grips work for me, just weld a bolt to the edge, and a couple of nuts to hold the eyelet of the wire . Also can hold pieces as well.
R
Gallery updated 11/01/2011
