Jon Ison
posted on 6/12/07 at 06:24 PM |
If I wanted too.......
Make a sorta rear flat bottom/undertray/diffuser sorta thing out of say 3~4mm thick plastic type stuff.........
Would if I warmed it up with an air dryer, I be able to push a bit of a dished shape into it to clear the diff ?
eta
This sorta stuff ?
[Edited on 6/12/07 by Jon Ison]
posted on 6/12/07 at 06:32 PM |
You could definitely do it with a hot air stripper, press it over the dog bowl Jon.
Jon Ison
posted on 6/12/07 at 06:51 PM |
Or the wok swimbo uses to iron me t shirts..........
posted on 6/12/07 at 07:06 PM |
That'll explain the hump then
Ivan
posted on 6/12/07 at 07:27 PM |
If a hot air gun will soften the plastic then won't the heat from the engine bay cause it to sag over time?
posted on 6/12/07 at 07:47 PM |
It's going under the diff, it's quite a bit away from the engine bay
Paul TigerB6
posted on 6/12/07 at 07:50 PM |
I'm guessing not as it will be used at the rear of the car like this and so should be cool enough
diffuser
Jon Ison
posted on 6/12/07 at 08:30 PM |
Is it me or is her head on the wrong way around in the 3rd photo ?
eta, whats happening down below in the 4th pic, is it covered ?
bob
posted on 6/12/07 at 10:53 PM |
Extra slit in that bonnet
trextr7monkey
posted on 6/12/07 at 11:10 PM |
Back to the plastic - eyes front all you droolers!
Jon it will bend with hot air gun - you might want to borrow a couple with mates atached if you are wanting to make a large bump-we have an oven at
work and the kids do plug and yoke moulding which is a bit like vac forming without the need for a vacuum forming machine.
If you start getting a rubbery smell it is probably getting a bit on the hot side.
4 mm will be fine -we use this thickness in abs for wheelarch extensions as it is rigid enough to look like body work but flexible enough not to take
off an innocent by standers leg.
BTW What size will your product be as we have a vac former too but it won't cope with massive things- makes battery box covers etc
atb
Mike
