Author: Subject: Glass beads or Aluminium Oxide.......near Oxford?
Sacal
posted on 17/12/07 at 08:29 PM Reply With Quote
Does anyone know where i can buy blast media near Oxford? Closest place i can find is Machine mart in Swindon which is a good 50-60 mile round trip. Could buy online but delivery is a little excessive for small amounts. Could really do with getting these ali carbs cleaned up to give me some inspiration
Oh...sand wont do bec i want it to look like a proper job
Thanks a lot!
bonzoronnie
posted on 17/12/07 at 09:10 PM Reply With Quote
Blast media
I know you dont want to use sand. But
I go to my local pet warehouse & buy Bird cage sand. ( Large bags )
Very, Very fine & dry. Needs to be run through a sieve to remove tiny bits of shell.
It consists of tropical beach sand. Very sharp and at the same time, a soft & gentle blast medium.
I have used it to great effect on soft intricate alloy parts.
Probably a little softer than All/Oxide
Ronnie
wilkingj
posted on 17/12/07 at 09:20 PM Reply With Quote
I use Swimming Pool Filter sand.
MAJOR warning.
Make sure the "exhaust" on your cabinet is well filtered.
I extract through TWO sponge filters, into a Panasonic hoover with micro filters fitted.
I also use a decent dust mask with a rubber seal to the face. #
Dont use those cheap paper masks on this job.
The dust from the sand, is nasty and can cause sillicosis (Lung Disease that Miners get).
So if you use anything Dangerous, consider the hazard to your health before doing anything else.
OK I'm a skinflint, (Just broke really!)
I use sand as its cheap. BUT PLEASE CONSIDER THE HEALTH RISK FIRST.
Jut cos I do it, doesnt make it safe for anyone else.
Health and Safety would march you out of a factory if you did this at work.
Hence me using lots of filtering, and a decent facemask, and I think I still could be taking a risk. Do dont follow my example.
Oh... Glass beads for Ally, and Grit / Oxide for Steel.
Best Regards
Geoff
http://www.v8viento.co.uk
bonzoronnie
posted on 18/12/07 at 09:04 AM Reply With Quote
Sand
MAJOR warning.
Yes I could have mentioned the health & safety aspect. Of Blasting
I for one allways use my air-fed mask when blasting.
I think the above rules should apply to all blasting ops.
You never know what nasties are in the air,
Ronnie
