joolsmi16
| posted on 2/1/08 at 06:56 PM |
escort rack end joint
Hi all, any tip on unthreading the ball jointed arms from the escort rack?? I've have a go and failed to wanting to over do it before checking
if I've missed something.
Also if anyone can has the section from the haynes to dismantle that would be a great help.
Jools
turbodisplay
| posted on 2/1/08 at 07:54 PM |
Plumbers wrench (pipe wrench), designed to grip and tighten onto pipes.
Use a vice with alli to protect the rack.
Darren
Bob C
| posted on 2/1/08 at 10:32 PM |
if it's oem escort rack you need to drill out the 2 lock pins before anything will unscrew. I have a pdf of the relevant manual pages - if you
want it send me a U2U with your email address
Bob
| posted on 3/1/08 at 12:26 PM |
I believe the bits holding the track rods in place have roll pins which need to be drilled out. Roll pins are hollow hardened steel designed to grab
a drill bit and snap it off!
