jabbahutt
| posted on 11/1/08 at 01:50 PM |
cutting tube at required angle
Afternoon all
quick question as I'm after an idiot proof method to get a reasonable result.
I'm trying to cut across a 100mm diamtyer plastic pipe/tube at an angle of 18 degrees.
I only have access to basic tools and a workmate so no bench saws etc. Any ideas as to how to get a reasonably accurate cut as I've tried
putting tape etc round but of course because it's curved I made a complete bodge of it.
Any assistance much appreciated as it'll allo me to get rearof car finished this weekend.
Cheers all
Nigel
Bluemoon
| posted on 11/1/08 at 02:03 PM |
You can get program (no idea what someone will be along in a second) to draw a template that you wrap around the pipe..
Dan
nitram38
| posted on 11/1/08 at 02:20 PM |
3 blocks of wood formed into a U channel.
Mark a line and use a saw to cut your angle on each side, place pipe in U and recut the pipe using the cuts in the wood as a guide for your saw
blade.
Phil.J
| posted on 11/1/08 at 02:38 PM |
A mitre saw and jig might do the job.
jkarran
| posted on 11/1/08 at 03:00 PM |
Clamp a couple of pieces of steel tube upright ~5" tall, ~5" apart in the workmate.
Mark 18deg on the workmate table with a protractor, clamp another piece of wood or steel to that line.
Hold the pipe against the piece you just clamped and between the uprights. Run your saw down the uprights.
Or some variation on that theme to make use of whatever scraps and tools you have.
jk
NigeEss
| posted on 11/1/08 at 03:39 PM |
blade.
Are you thinking of TUBEMITRE ?
AFAIK it's for making the fishmouths for round-round rather than a straight
angle to a flat.
| posted on 11/1/08 at 04:09 PM |
I couldn't get tubemitre to give a shape to fit to a flat surface.
I used a hand mitre saw in the end - which was a PITA as the cheapo B&Q saw was rubbish. Got my money back in the end.
[Edited on 11/1/08 by David Jenkins]
