clairetoo
posted on 17/5/08 at 10:19 AM |
Syncrometer ?
Hiya all - does anybody in the Leicester area have a syncrometer I could use to balance my throttle bodies ? I would be happy to drive the car to you
if its not too far .
Claire .
Its cuz I is blond , innit
Claire xx
Will weld for food......
mr henderson
posted on 17/5/08 at 11:01 AM |
Claire .
There's a much easier way. Get a length of plastic tubing such that one ond can fit comfortably into one of your ears, or rig up some kind of
adaptor.
Then, run the engine and hold the other end in the airstream to each TB in turn. You can judge the airflow by the hiss produced. Obviously you need to
hold the tube at the same relative position in each TB.
[Edited on 17/5/08 by mr henderson]
jacko
posted on 17/5/08 at 11:53 AM |
Try Halfords thats were i got mine not a bad price
MikeR
posted on 17/5/08 at 11:56 AM |
i've got one but its with another forum member. The tube method is supposed to be better as mine (designed for SU's but will still work)
is affected by the pulse of the throttle body.
If you still want to try it let me know and i'll get mine back.
(or go to the Leicester meet up and get fireman sam (can't remember the username - yellow stuart taylor fireblade) to lend it to you).
posted on 17/5/08 at 01:10 PM |
The trick to getting good results is to hold the tube/stethoscope at exactly the same relative position for each intake.
posted on 17/5/08 at 03:12 PM |
I tend to use a mechanics stephascope ? with the probe bit removed , just place the pipe into the T/Bs at BT suggests. Find it works better for me
than a single pipe and leaves a hand free for tweaking .
andybod
posted on 17/5/08 at 03:16 PM |
i've got a gunsons one was a bit cheap but works you are welcome to borrow it in swadlincote if thats any good to you
clairetoo
posted on 17/5/08 at 06:12 PM |
U2U sent
Claire xx
owelly
posted on 19/5/08 at 01:38 PM |
If using the tube/ear method, don't actually stick the tube in your ear 'ole! Unless you need your ears slurping out!
Just hold the tube near your ear!
http://www.ppcmag.co.uk
clairetoo
posted on 19/5/08 at 06:54 PM |
.............pardon ?...............
Claire xx
NS Dev
posted on 20/5/08 at 08:09 PM |
I have a proper synchrometer, that works, and I also now have it back in my garage!
MikeR, sorry but that one you lent me is no good, not for a 2.0 engine at any rate, on any damper setting it just bounces from one end of the scale to
the other!!!
I have a proper one if you want to borrow it! (fireman dave had borrowed it but he brought it back a while ago)
PS claire, u2u sent
[Edited on 20/5/08 by NS Dev]
clairetoo
posted on 20/5/08 at 08:34 PM |
U2U replied to
Claire xx
