A1
| posted on 23/9/08 at 03:13 PM |
cutting glass fibre
whats the best way?
would you cut from the good surface to the inside?
edspurrier
| posted on 23/9/08 at 03:18 PM |
I found a Dremel type tool with a cutting bdisc by far the easiest and neatest way. Use a dustmask, goggles (you'll get through a few discs and
it won't cut curves) and put the hoover pn with a nozzle nearby.
tegwin
| posted on 23/9/08 at 03:38 PM |
I have used a diamond coated tile cutting disk in an angry grinder to good effect.....gives a nice clean finish especially if you are cutting through
gelcoat
www.verticalhorizonsmedia.tv
Guinness
| posted on 23/9/08 at 03:45 PM |
I've used a normal hacksaw in the past, then a file to finish the edge.
Use plenty of masking tape too!
I also chain drilled and then the file for my exhaust hole.
Mike
stevec
| posted on 23/9/08 at 04:24 PM |
Tile cutting saw works good aswell.
Steve.
Triton
| posted on 23/9/08 at 04:49 PM |
Drill bits best left blunt too, the ideal one is a spot weld drill as it has a centre "pip" to pick up your centre then cuts like a
milling cutting....nice clean hole.
silverline do diamond blades for grinders at about £2.50 and work just as well as the £25 ones, mine has lasted 2 years of abuse so £2.50 well spent
methinks!
Mark
www.tritonraceseats.com
www.hairyhedgehog.com
mr henderson
| posted on 23/9/08 at 04:54 PM |
Depends a bit on what you are shape/size you are cutting
I cut some recently with an Eclipse coping saw, from the gel coat side, just a little outside the line required, and finished to the line with some
sanding belt (made for belt sanders, just tear it ti the sizes required) over various shaped sanding blocks.
It worked very well, and I would recommend the technique if you were in a situation where an angle grinder would be too difficult to control, or where
a slip would be expensive
John
[Edited on 23/9/08 by mr henderson]
twybrow
| posted on 23/9/08 at 06:33 PM |
Masking tape on the gel coat side, then a normal hacksaw blade.
| posted on 23/9/08 at 07:02 PM |
I saw a bloke on TV cutting GRP with a vibrating blade similar to the ones used for cutting off plaster casts - are they available to us non-medical
mortals?
mr henderson
| posted on 23/9/08 at 07:31 PM |
mortals?
Yes, it's called the Fein MultiMaster. Apparently there's a cheaper Bosch version too. The blades are pretty expensive though, so I only
use mine when I have too. I used to fit kitchens, and every now and then a situation would crop up and that tool was the only way to deal with it
John
LBMEFM
| posted on 23/9/08 at 07:36 PM |
Wear rubber gloves too, the fibres will drive you crazy.
Barry
| posted on 23/9/08 at 09:33 PM |
mortals?
They're pretty mad. I used one to chop up my cadaver @ med school. You could hold it right up against your (gloved) skin and it would just rub
it gently but hold it against bone and it would chop through it like a knife through butter!!!! Spooky....
Chippy
| posted on 23/9/08 at 10:09 PM |
I have always found that a jig saw with a grit edged blade works fine. Put a good layer of masking tape around the area to be cut, so that the base
plate doesn't bugger the gel coat. Good for cutting curves as well. HTH Ray
| posted on 24/9/08 at 07:49 AM |
Too much information... much, much too much...
