| posted on 21/10/08 at 12:29 PM |
recommendation for TIG welder?
Can anyone recommend a TIG welder, ideally one that you are using?
needs to be 240 V single phase.
Plan is to weld steel DOM tube, 3 mm wall thickness together and same tube but to 6 mm steel plate.
budgie wise, dunno, £ 500.
If there is something that'll do AC TIG of aluminium then could push out to be £ 1 k.
Prices ^^^ include torch.
For the above requirments, what sort of spec. would I be looking at?
Will mostly be welding 1.5 inch tube as opposed to metre long runs of plate.
What a the "good" brands and what are the ones to avoid?
[Edited on 21/10/08 by 02GF74]
UncleFista
| posted on 21/10/08 at 05:22 PM |
More of a specialist audience here
Tony Bond / UncleFista
Litemoth
| posted on 21/10/08 at 06:23 PM |
I think that's for a M.I.G. audience not a T.I.G. audience. The Tiggers have deeper pockets than Miggers. Never the twain.
907
| posted on 21/10/08 at 06:30 PM |
Hi.
It would be my advice to buy a recognized make.
If that means that your budget will only stretch to a second hand one, then so be it.
That's what I did. Tig welders pay for themselves many times over, given time.
Paul G
Hugh Paterson
| posted on 21/10/08 at 06:45 PM |
Tig welders
I would suggest u look at the fronius range, a search should find em and your local supplier, I have an ac/dc Tig of theirs and its the bees knees, an
ex hire or demonstrator would be in your budget I reckon.
Shug
zilspeed
| posted on 21/10/08 at 06:51 PM |
There's plenty of tig talk on there too.
mark chandler
| posted on 21/10/08 at 07:34 PM |
I have a commercial unit, similar to a miller unit. Most yank stuff can be strapped for single phase but you need a fat wire to the company fuse, mine
will draw over 100amps @ 240 at full power so I never stray there!
If getting a second hand one try and ensure you get a foot pedal and water cooled torch if you are looking at doing Ali.
Something like this would be ideal.
Miller
Regards Mark
mad-butcher
| posted on 22/10/08 at 06:34 PM |
Get in touch with a guy named weldequip on the mig welding forum
Tony
