eznfrank
posted on 24/10/08 at 09:54 AM |
Making a radius tool
The car's getting close to being finished now and I'm starting to think about the SVA prep work. Am I right in thinking if I get a bit of
wood, steel or whatever and drill a 5mm hole in it then lop it in half that will be similar to what the SVA man will use to test the radius of
sticky-outy bits?
I take it if the edges are resting on something then nothing must be able to touch the inner of the semi-circle?
smart51
posted on 24/10/08 at 10:02 AM |
drill a 5mm hole then cut out a corner of the piece so that the straight edges go to the edge of the circle. You then have an L shaped piece with a
2.5mm internal radius.
DarrenW
posted on 24/10/08 at 10:31 AM |
That is one decent way to make a rad gauge. You may also find a set for not too much money at an tool suppliers.
In the past ive tried to measure them with a set of verniers. Not terribly accurate if the rad is borderline but gives you an idea how close you are
to the spec.
matt_claydon
posted on 24/10/08 at 10:41 AM |
That's the usual way of knocking one up, however standard radius gauges are a quarter of a circle, not a half. If you use a semi-circle you
won't actually be able to get it onto most radii to measure them.
smart51
posted on 24/10/08 at 11:19 AM |
Or you could buy one of these for £8.32
eBay link to set of radius gauges
