jabbahutt
posted on 30/10/08 at 08:47 AM |
stopping small coolant leaks
Morning all
Last night I noticed that i still have a small coolant leak on the pinto. It's seems to be originating from where the hose connects to the
automatic choke on the 32/36 weber.
I've gone round and ensured that all the hoses are on properly and the clips are done up nice and tight, could it be that the casting
isn't very smooth and causing problems creating a decent seal?
Any tips for sorting this out as even though it's only a small amount it's makes me wonder what it would develop into when the engine is
being run properly
Nigel
mad-butcher
| posted on 30/10/08 at 08:57 AM |
nigel
son't know what part you mean whether it's a large or small pipe. as mines a bike engine but is it a jubilee or proper hose clip, if
it's a small pipe sometimes a jubilee clip won't form a proper circle, try cutting back the pipe a bit.
Tony
and zebedee said it's time for bed
jabbahutt
| posted on 30/10/08 at 09:05 AM |
Tony
It's quite a large diamter pipe and held with jubilee clips. One end is fine but the automatic choke end seems to be leaking slightly. I take
it that you mean that the end part of the pipe may be knackered and cut it off to try a fresh piece further down? The only problem with that is
it's a preformed Ford pipe and if I cut an each or so off the end it then propbably won't reach to connect as it goes round the front of
the carb.
Nigel
Dangle_kt
| posted on 30/10/08 at 09:16 AM |
Try taking off the jubilee clip and seeing if the where the screw is located is causing a gap i the seal. If you have used an oversized one then then
don;t form a proper circle round where the screw is, and therefore don't always seal properly.
This would lead to the small leak you describe.
Worth checking. Replacing it with a proper hose clip would solve this.
jabbahutt
| posted on 30/10/08 at 10:23 AM |
thanks, any idea where i can get these proper hose clips, I've seen them in photos but never seen them anywhere for sale.
Nigel
| posted on 30/10/08 at 10:46 AM |
Hi Nigel,
You can get proper hose clips (sometimes referred to as fuel line clips) from Car Builder Solutions, Vehicle Wiring Products and usually from a good
motor factors.
One other thing to check - is the leak actually from the hose joint or from the auto choke unit itself. IIRC the choke mechanism bolts onto the body
of the carb - could be a leaky gasket.
mad-butcher
| posted on 30/10/08 at 05:59 PM |
there's a majpr motor factors along side the motorway which you get to by the roundabout near you but for the life of me I can't think of
the name, It is for just this reason that the SVA don't like jubilee clips on fuel system.
Tony
001Ben
| posted on 30/10/08 at 06:24 PM |
Nigel
Tweeks sell them. I used them on mine since the start and haven't had one leak.
mad-butcher
| posted on 30/10/08 at 06:48 PM |
T & G Autoparts
unit 20
Telford Road
This is the firm that motorworld use
Tony
