MikeR
posted on 1/11/08 at 10:48 AM |
Whats the diff between bright and black steel?
I'm asking as it seems its about .5mm at my local steel stock holders.
Just bought some steel, they used two strips. The blackened has rounded edges and is 2.85mm whilst the bright has square edges and is 3.3mm.
Bit miffed to get home and notice the difference. Luckily the bloke cutting mis read the instructions and i've got too much bright (so enough to
do what i wanted just out of that - but i have to do lots of my own cutting).
Hammerhead
posted on 1/11/08 at 11:08 AM |
I don't know but if its for the yacht you might need stainless (the winds just changed btw)
r1_pete
posted on 1/11/08 at 11:18 AM |
Black is hot rolled, Bright is cold rolled.
Triton
posted on 1/11/08 at 12:17 PM |
as said above and sometimes black not exactly very accurate especially the box section......
lots of cheap and nasty Chinese steel out there with crap in it you won't see until you try to gas cut it or weld it.
bright usually comes in shorter lengths than black....don't know why just always has.
Mark
www.tritonraceseats.com
www.hairyhedgehog.com
hellbent345
posted on 1/11/08 at 12:37 PM |
yup as mentioned above, hot rolled and cold rolled, its the hot metal reacting with the air a forming a black scale, also bright has/may have some
post rolling operations to make it exactly the size needed, whereas black doesnt have that (hence rounded edges etc) - black should be cheaper...?
[Edited on 1/11/08 by hellbent345]
posted on 1/11/08 at 01:05 PM |
On a practical note, the black steel will be easier to bend without cracking - the bright will probably need to be red-hot to achieve the same result.
mad-butcher
posted on 1/11/08 at 03:21 PM |
Isn't bright steel sometimes refered to as enginering steel because of the sharp edges and yes it desn't like to be bent cold.
Tony
posted on 1/11/08 at 08:01 PM |
Strictly speaking "Bright" only refers to the surface finish not the the grade of steel or manufacturing method although in practice
bright steel is always cold formed.
posted on 1/11/08 at 09:33 PM |
I've always known 'bright' as BDMS - bright drawn mild steel - referring to the way hot steel is drawn through dies to get the
correct shape. The action work-hardens the steel, which is why it can crack when bent.
posted on 3/11/08 at 09:57 AM |
Had the opposite experience with some angle iron I bought from B&Q (yes, they are rip-off merchants but only needed a short length). It was black
steel, rough scaly finish and I tried to form a frame by cutting out V's from one side and bending, but a single 90 degree bend cracked the
metal every time.
