fatfranky
| posted on 5/9/04 at 10:02 AM |
Don't wish to urinate on anyone's toes here but i thought it was illegal to use car brakes for a trailer. I think earlier in the post you
asked about reference material, about 5 years ago i bought a book from my local indespension dealer for a couple of quid that lists all sort of
info.
Amongst other things it lists some basic legal info (weights, lighting, good practice etc.) a catalogue of all their products and also plans for
different types of trailer. I'm sure that amongst all this it also states that it is illegal to use car braking mechanisms as they are not type
approved.
I'm not advocating using Indespensions products, as one trailer builder put it "we stopped using them when the price went up and the
quality went down" but this book is useful as reference material.
Hope this helps
mad4x4
| posted on 7/9/04 at 11:33 AM |
Trailer brakes usually have collapsable shoes so that you can reverse. Car's dont; mmmmm
Scot's do it better in Kilts.
ewanspence
| posted on 7/9/04 at 02:44 PM |
thanks for all the inputs
trailer design will now change. I have checked with plod and the they have given me info to help my trailer build.
What I am going to do is build a couple of small unbraked box trailers, sell them and then use the cash towards my big trailer build.
I have just aquired a twin axle horsebox which should be an ideal base for a twin axle car trailer.
I have also now fitted the removeable towbar to my Merc so there is nothing stopping me storming away with alll of my builds (MegaGrip, 2 box
trailers, big ramps and a twin axle car trailer....oh except the pending birth of my first born   due on Friday but I do get 1 months holidays as
parental leave though
Ewan.
Visit the MegaGrip site :-
http://www.geocities.com/ewanspence/
Terrapin_racing
| posted on 10/9/04 at 02:17 PM |
Trailers manufactured after October 1982, which require brakes, must be fitted with a braking system complying with EC Directives. Since 1989 only
auto reversing brakes comply.
It is vitally important that the trailer coupling and the trailer brakes are compatible.
If brakes are required they must be fitted on all road wheels. Linings must be Asbestos free.
Trailers manufactured after October 1982 must be fitted with a coupling, which includes a hydraulic damper.
Spring overrun couplings can be fitted as a replacement item on Pre 1982 trailers.
All road going trailers/caravans must have a suspension system fitted between the wheels and the chassis frame except for Agricultural trailers used
at speeds of less than 20 MPH and trailers used solely for hauling felled trees.
Tyres must be capable of carrying the gross load of trailer Do not mix Radial and Cross Ply on the trailer
Current legislation on tyre wear applicable to vehicles is also applicable to trailers.
Tyre pressures should be as recommended by the manufacturer. A comprehensive guide is given in the Technical Section.
All radial tyres must be `E` marked.
Retread tyres must comply with BSAU1446 and be so marked.
All trailers/caravans must be fitted with mudguards to catch grit and dirt and reduce spray thrown up by the wheels unless the body of the trailer
gives adequate protection.
All trailers and caravans must be fitted with an approved style numberplate bearing the same number as the towing vehicle.
If brakes are fitted they must be in working order. Even on trailers where brakes are not compulsory.
[Edited on 10/9/04 by Terrapin_racing]
