Grayo
posted on 10/8/06 at 04:37 PM |
I'd definitely go with SeaBass on this one.... The biggest danger is becoming complacent and leaving the chuck key in the chuck. When I use the
lathe (which is nowhere near as frequently as it used to be!), I always make a check that the key is back in its holder before hitting the start
button.
I would also say that the 3 jaw concentric chuck is nice and simple for beginners, but not near as flexible as a 4 jaw. You've just got to get
the knack with a 4....
Bottom line with any machine tool is to respect it for the danger it can pose to you!
NS Dev
posted on 11/8/06 at 07:12 AM |
another one on the three jaw thing!!
Four jaw is ALWAYS used when accuracy is important, three jaw is fast but not that accurate.
I generally use my lathe for boring bits and bobs out and making spacers, bush tubes, top hats etc ect but couldn't do without it!!!
Its a Colchester Master 6.5" roundhead, anybody got a decent 4 jaw chuck for one???
One of the really useful little things I have used it for is welding up driveshaft adaptor flanges concentrically and square. I turn the two halves
for a press fit, put one in the chuck, and push the other in with the tailstock.
I then clamp it in with a revolving centre in the tailstock, cover all the lathe bed etc up with a thick blanket, put the mig's earth strap onto
the revolving bit of the revolving centre (so I don't weld the bearings up! ) then tack and weld round. Lathe won't go slow enough to
rotate itself, so I turn it with one hand and weld with the other, using the toolpost as a wristrest.
