Author: Subject: painting wishbones
Miks15
posted on 12/11/08 at 09:12 AM Reply With Quote
painting wishbones
What is the best paint to use on my wishbones? And does it need a primer etc?
Sorry for being vague but im a bit dumb when it comes to paint
tegwin
posted on 12/11/08 at 09:33 AM Reply With Quote
IMHO.. The POR15 paints and preperation products from frosts are very very good.... Not cheap... but worth it IMHO!
www.verticalhorizonsmedia.tv
Mr Whippy
posted on 12/11/08 at 10:06 AM Reply With Quote
How about wrapping it in carbon fibre cloth, for all the material it would use...
might look good with the pivot tube painted gold then the whole thing lacquered, might be a bit chav for some
DarrenW
posted on 12/11/08 at 10:08 AM Reply With Quote
Dont know about paint im afraid but from experiance when prepping them for paint remove any sharp (square) corners from the plates - id be gently rounding them off (small rad) first.
Pdlewis
Why not send them and get them powerder coated? alot of places will coat black for not much cash
Build Photo Album
Updated 05/02/2009
Miks15
posted on 12/11/08 at 10:32 AM Reply With Quote
hhmmm powdercoat is an option i guess, Can you touch up powdercoat with paint? Knowing me ill end up putting some chips in it along the way,
Also i want to paint them blue
Daddylonglegs
posted on 12/11/08 at 11:17 AM Reply With Quote
After having seen this http://www.electrostaticmagic.co.uk/ working at the Stafford show I am thinking of putting it on my Xmas wish list
Excellent finish and V.quick. Be great for things such as W/Bs
Bit long-winded for a chassis I guess, I don't have an oven big enough!
mikeb
posted on 12/11/08 at 11:29 AM Reply With Quote
I'm acid etch priming mine, with a enamel top coat.
I've heard they get chipped quite easilly so this way once a year I can give them a quick refresh if needed.
Apparantly applying the top coat while the primer is still part wet (flashed off) is the best way.
I'm no expert though!!
dinosaurjuice
posted on 12/11/08 at 01:09 PM Reply With Quote
£109??? surely worth a go. theres an appliance recycling centre near me, time to enquire about a second hand fan oven...
anyone know how much the powder is and how much gets used per meter square?
edit: sorry for hi-jacking post miks51
[Edited on 12/11/08 by dinosaurjuice]
3GEComponents
posted on 12/11/08 at 01:13 PM Reply With Quote
We'll powder coat your wishbones for £40 + the VAT & return delivery.
Regards
John
[Edited on 12/11/08 by 3GEComponents]
Daddylonglegs
posted on 13/11/08 at 04:17 AM Reply With Quote
The guy at the show doing the demo said that 2 bags of powder would probably do a chassis and IIRC it was around £10 a bag (Candy was a little more expensive).
He also said that they tend to use a chamber type set-up so they can re-cycle the unused powder. But for the chassis he was assuming wastage as well.
I will definitely be trying for one so I can sort out some stuff on my VFR750 too
Ditto for the hijack too
