Author: Subject: DIY gimball
posted on 12/11/08 at 11:43 AM Reply With Quote
DIY gimball
... I think that is what is called.
I need to make some attachment that fits onto a bike handle bar, 25 mm dia, that holds a pair of objects which can be adjusted up/down and left/right. It needs to be light too.
(the object will be a pair of LED lamps)
ideas?
is something like that already available?
For those who don't know what I'm on about, it is the clamp thingy that holds this lamp to the handle bars. It probably has a ball joint so it can be adjusted.
[Edited on 12/11/08 by 02GF74]
Mr Whippy
posted on 12/11/08 at 11:52 AM Reply With Quote
? haven't a clue what you are on about
possibly some sort of light bracket for a motorbike by the sounds of it???
eznfrank
posted on 12/11/08 at 12:02 PM Reply With Quote
A gimbal is like a frame, usually two inner circles that allows thing like ships compasses etc to stay upright when a ship rolls, they even have them on ovens on ships so that pans don't fly around everywhere - is that what you mean??
Edit - you put a pic up now, so no, it's not that.
Unless you meant Gimpball, which is something entirely different!!!
[Edited on 12/11/08 by eznfrank]
adithorp
posted on 12/11/08 at 12:12 PM Reply With Quote
Don't the lights come with brackets?
All the bike lamps I've had (dozens) rotate the clamp on the bar to adjust up/down and are fixed in the streight ahead position.
ps. I think its "Gimble"
adrian
[Edited on 12/11/08 by adithorp]
http://jpsc.org.uk/forum/
Mr Whippy
posted on 12/11/08 at 12:13 PM Reply With Quote
LED's on the handle bars...? sounds a bit chavtastic tbh
is it a motor bike or a pedal one?
posted on 12/11/08 at 12:23 PM Reply With Quote
no, high power SEOUL white LEDs, help me see when I am going on the mountain bike. like below. In the centre is a high power LED mounted on an aluminium heatsink. It will fitted with a holder and lkens and be housed in short length of copper pipe.
Mr Whippy
posted on 12/11/08 at 12:33 PM Reply With Quote
Oh I see
They look fancy for sure, are they expensive? I need some lights for a big r/c plane but haven't found any LEDs bright enough to look like realistic landing lights.
DarrenW
posted on 12/11/08 at 12:40 PM Reply With Quote
I seem to think RS might do similar types of clamps but they probs add RS tax to the prices.
What about a bullet cam clamp (probs cost more than shop bought light sets though).
i guess a locost clamp would be block of ali with 25mm hole through, cut in half and bolted together around the handle bars. Then maybe threaded bar for the upright and clamp lights to that.
posted on 12/11/08 at 12:45 PM Reply With Quote
are they bright? F***K yeah!! They will melt your eyeballs
These babies take 1 A current, compare that to 20 mA for little LEDs.
If you ever looked directly at the little LEDs, you know how bright they are; imagine these being approx 50 x.
Think I paid £ 8 but that was a year ago, I bet the price has dropped.
You can buy them unmounted as the heatsink is quite big. For best results you need a special driver - circuit that allows connection to battery without having a lossy drop resistor (wasted heat).
You can get different type of lenses - these determine the angle of the beam. Thens is 20 mm in diameter; may be too big for your teeny plane.
see http://www.led-tech.de
lens is like this: <--- linky
carclo optics.
I got the boards from China, the LEDs, lenses from Germany and the copper tube from B&Q.
Mr Whippy
posted on 12/11/08 at 01:06 PM Reply With Quote
sound well bright enough, thanks for the link
planes not all that teeny really, 144" 1/3 scale pipercub
Rod Ends
posted on 12/11/08 at 04:38 PM Reply With Quote
How about this?
tomprescott
posted on 12/11/08 at 04:40 PM Reply With Quote
Have you thought about some rubber strip and a couple of jubilee clips? Might not look that great but will be cheap as chips!
DarrenW
posted on 12/11/08 at 05:01 PM Reply With Quote
Another idea
http://www.cameras4sports.co.uk/product.php?xProd=66&jssCart=8c1124d8bfcb34ca65a3fbac72c722b2
TOO BADD
posted on 12/11/08 at 07:27 PM Reply With Quote
Gimball Raleigh
posted on 13/11/08 at 07:49 AM Reply With Quote
thanks all - ~i had come across the DX site from another forum. looks like I will be ordering some stuff from there.
