smart51
| posted on 15/11/08 at 04:09 PM |
How strong is solvent welded plastic?
I've just made a headlight cover out of perspex which I "glued" together using solvent welding fluid. I'm fairly pleased with
the result but I don't want to try breaking it to see how strong it is. How strong is solvent welding usually?
Echidna
| posted on 15/11/08 at 04:24 PM |
Could you provide the brand of this fluid?
Are we talking about chemical or mechanical bonding? The first is better of course!
r1_pete
| posted on 15/11/08 at 04:25 PM |
If the solvent and perspex are compatible, and the solvent has actually desolve the perspex to 'weld' it together, you'll probably
find the perspex will break before the joint, it is very strong.
COREdevelopments
| posted on 15/11/08 at 04:51 PM |
i used it to glue my spud launcher together as it was made from drainage pipe. it never came apart except for the screw on end cap which shattered
after a fair bit of use,
rob
mr henderson
| posted on 15/11/08 at 04:54 PM |
Basically the same as welding, need to ensure plenty of contact area and compatible materials
smart51
| posted on 15/11/08 at 05:19 PM |
The fluid is called poly-weld. It says acrylic on the bottle and to be fair, it seems to have done the trick.
mr henderson
| posted on 15/11/08 at 05:29 PM |
Well, Perspex is acrylic, so that would seem to be ideal
John
[Edited on 15/11/08 by mr henderson]
Lars
| posted on 15/11/08 at 10:01 PM |
WOuld this sort of suff be strong enough to change the in/out-let of a car radiator?
| posted on 16/11/08 at 10:41 AM |
I doubt if the radiator will be acrylic, you need something like JBweld or Araldite industrial. There's also Devcon which should do it too, try
googling round.
