smart51
posted on 15/11/08 at 04:10 PM |
polishing perspex to transparency
I've just made a headlight cover out of perspex but right at the end spilled a bit of solvent welding fluid on it which has marked it slightly.
What do you use to polish perspex to transparency?
aaron bassett
posted on 15/11/08 at 04:16 PM |
you could try brasso it polishes prespex nicely
dubstar_04
posted on 15/11/08 at 04:59 PM |
People used to recommend that phone screens were polished with brasso and fine wire wool.
I have never tried it but its worth a thought.
posted on 15/11/08 at 05:23 PM |
We used a buffing mop and Farecla compound on a scratched bike headlamp and it fetched it out, you might have to use a couple of grades though.
mr henderson
posted on 15/11/08 at 05:31 PM |
Drawing a stanley knife blade across the perspex, with the blade at approx right angles to the surface, can work surprisingly well, particularly good
on edges
John
triumphdave
posted on 15/11/08 at 05:50 PM |
I have heard you can use toothpaste,although I have never tried it myself.
Mark Allanson
posted on 15/11/08 at 06:56 PM |
DON'T USE BRASSO!!! It contains ammonia which will cloud ant acrylic, Farecla G7 or similar
blakep82
posted on 15/11/08 at 08:43 PM |
tooth paste works well on CDs and phone screens. might take a loooooong time to use to polish out the headlight covers. but maybe with the use of one
of those polishing attachments on a drill/dremmel or something?
________________________
smart51
posted on 15/11/08 at 08:45 PM |
1200 grit paper removed the mark, cutting paste knocked that back to a haze and toothpaste restored the transparency. Not 100% perfect but good
enough. Thanks chaps.
blakep82
posted on 15/11/08 at 08:47 PM |
have you got any photos of the light units so far now?
myke pocock
posted on 15/11/08 at 08:57 PM |
No, no, NO do not use fine wire wool on any account. Only use a very fine wet and dry if it is badly marked and with loads of water and
soap. Try Solvol Autosol or T Cut with a soft rag then you could try some toothpaste if you want to realy buff it up.
posted on 16/11/08 at 07:46 AM |
depends on what you mean by trasnparency. I have used toothpast as well asthe farcled compounds, the very fine stuff too but when the item is
examined closely, there are still very small marks visible so I hjave never got it as good as new.
smart51
posted on 16/11/08 at 10:21 AM |
See this thread: Locost builders
posted on 16/11/08 at 11:12 AM |
I've used Autosol with good effect on plastics before. After that a bit of toothpaste as mentioned should do the trick!!
