zilspeed
| posted on 24/11/08 at 06:32 PM |
Friction stir welding
Never heard of this before.
I knew of the friction welding process. I had remembered reading a story in CCC of how David Finlay had
modified his gearbox when a friend friction welded two different gearshafts together giving hybrid ratios. So, a quick youtube search showed a few
videos - neat, so that's how friction welding works.
But the associated link showed friction stir welding too.....
Basically, heat the metal by spinning a tool against the surface until it melts at which point the tool is plunged into the molten metal where it
stirs the metals from either side of the join. This is other worldly to me this sort of stuff.
Try Here
Great Stuff
UncleFista
| posted on 24/11/08 at 06:38 PM |
Yay, I thought I was weird, and now Zil shows me I am, but I'm not the only one
I spent a good hour watching friction welding on youtube a couple of weeks ago, and saw that "stir" welding vid. Clever stuff, it's
what holds airbus wings on so I believe
I have to say, it's the bigger stuff that impresses me
[Edited on 24/11/08 by UncleFista]
Tony Bond / UncleFista
r1_pete
| posted on 24/11/08 at 06:40 PM |
Very interesting, wonder if I can modify the ML7 lathe to do that
Mal
| posted on 24/11/08 at 07:09 PM |
I was shown this welding method on a visit to The Welding Institute about 10 years ago and found it very interesting.
It was like rubbing a totally blunt milling cutter along the joint line.
mangogrooveworkshop
| posted on 24/11/08 at 08:44 PM |
shucks good welding practice
I see and you see nothing after this
matt_claydon
| posted on 24/11/08 at 09:25 PM |
That's pretty neat. See also friction drilling which I'd not come across before (except when I use blunt bits!):
http://uk.youtube.com/watch?v=NhkWINPRK3A&feature=related
matt_gsxr
| posted on 24/11/08 at 10:50 PM |
If friction welding is so 'easy' why is it so expensive to get driveshafts made up in this way?
To me it looks like it would take about 20seconds for one of those friction welding machines to cut a section out of a driveshaft and then friction
weld it together.
I suppose the problem is the setting up.
Matt
DIY Si
| posted on 24/11/08 at 11:06 PM |
I'd guess that most of the cost is the machine itself and setting it up. Similar thing to getting tubes bent I suppose.
Sun Tzu, The Art of War
tycho
| posted on 25/11/08 at 03:13 AM |
The youtube videos posted are just a variation on friction welding.
Friction stir welding is a very different animal.
SeaBass
| posted on 26/11/08 at 06:40 PM |
OK let it out of it's cage and describe it to us!
tycho
| posted on 27/11/08 at 02:27 AM |
Well I will just bung a link up to the wikipedia on it:
Friction Stir Welding
The key point with friction stir welding (compared with normal friction welding) is that it occurs below the melting point of the metal. There was a
news article on Points West a few years ago as it is done at Filton on Airbus parts.
| posted on 27/11/08 at 10:08 AM |
It looks interesting but you couldn't use it in any practical way unless you are building an Airbus from the Haynes manual "Build an
Airbus for under £2.5 million and start a travel firm" though
