blakep82
| posted on 29/11/08 at 11:28 AM |
cutting slots in 5mm steel?
am i right in thinking you can get drills which drill a hole, and then half way up the shaft its got some kind of cutting thing to allow you to cut
slots? or am i way off?
________________________
aaron bassett
| posted on 29/11/08 at 11:32 AM |
you are right but they are only good for plastic really. if you want a slot best get it milled out using a milling machine
phelpsa
| posted on 29/11/08 at 11:40 AM |
I've got one I've used for slotting 3mm steel and it's worked really well.
However it does put a lot of stress on the drill in a direction in which it was intended to take it!
minitici
| posted on 29/11/08 at 11:53 AM |
Water jet cutting! Ideal for slots.
blakep82
| posted on 29/11/08 at 11:57 AM |
i thought as much about the drill type things... cheers guys, i know my drilling's going to end up being out. big washers needed i guess!
mmm waterjet cutting. if i had one i would also, if i had time, and knew how to do a CAD drawing i would. but i don't and i can't, so
for now, drilling it is
once the cars build and running and legal, i'll look to get some bits water/laser cut properly, but for now hand tools are the way
Danozeman
| posted on 29/11/08 at 12:08 PM |
Chain drilling and file it is for you then
Those drill bits are good for ali and thin steel but 5mm steel it will blunt straight away.
Dan
dave1888
| posted on 29/11/08 at 01:08 PM |
Drill hacksaw then file.
mr henderson
| posted on 29/11/08 at 03:30 PM |
Just get an adaptor for your pressure washer, and cut it by eye. CAD/CAM is for wimps. Dead simple!
John
flak monkey
| posted on 29/11/08 at 03:32 PM |
John
ROFL
Drill hole each end, 1mm slitting blade in angle grinder, and cut the slot away. You might need to finish each end of with a pad saw and hacksaw
blade, but its a lot less hassle than chain drilling
Sera
http://www.motosera.com
austin man
| posted on 29/11/08 at 07:34 PM |
Drill and jigsaw
blakep82
| posted on 29/11/08 at 08:49 PM |
i *think* i've managed to do a drawing in dxf format. it seemed a bit too easy though lol
Hugh Paterson
| posted on 30/11/08 at 10:20 PM |
Why dont u just give me an accurate drawing on fag packet and i will job it with a slot drill ya dobber
Shug
blakep82
| posted on 30/11/08 at 10:26 PM |
^ lol i keep forgetting
| posted on 1/12/08 at 10:55 AM |
Drill files work but they are slow and not very accurate, snatch Shug's hand off
mr henderson
| posted on 1/12/08 at 11:47 AM |
And tell him his avatar is a little bit wide, too
RickRick
| posted on 1/12/08 at 11:54 AM |
drill and files are perfectly accurate, even down to 0.02mm if you've got the time and the skills
iank
| posted on 1/12/08 at 02:42 PM |
John
ROFL
Then throw the disc away, they can shatter after grinding ally, which is a "bad thing"TM
Anonymous
