Author: Subject: 2" Tube Swage
907
posted on 24/12/08 at 10:43 AM Reply With Quote
2" Tube Swage
Hi All,
I have a little homework job on at the moment that involves exhaust pipe joints.
They are a pipe inserted into another pipe with lugs welded onto each piece and held together with springs.
I turned a former on the lathe and planned on using my 6 tonne bottle jack to force it into the end. Failed.
So I borrowed a 10 tonne bottle jack. Wooo Hoo. Piece of cake.
I'm sure Father Christmas reads Locostbuilders so I'd just like to point him in the direction of Screwfix who do a nice 12 tonne jobbie.
(always pays to have a bit in hand)
I live in hope.
Cheers, and Happy Christmas to you all.
Mr Whippy
posted on 24/12/08 at 11:00 AM Reply With Quote
I just weld on the end of a skip retrieved piece
rotax78
posted on 24/12/08 at 12:24 PM Reply With Quote
what did you use to jack against, obviously something that would take more than 10 tonne to move, but what?
Volvorsport
posted on 24/12/08 at 12:45 PM Reply With Quote
thats exactly how we do it .
just need to put some slots in it to make a perfect ID/OD joint
use some tallow aswell
www.dbsmotorsport.co.uk
getting dirty under a bus
907
posted on 24/12/08 at 01:06 PM Reply With Quote
Many many years ago I made a pipe bender to do w/bones.
Since then it's pressed bearings, in and out, bent brackets, (vee block) and pressed many a can end, and more.
A versatile tool.
I used copperslip for a lubricant as I had some handy.
Volvorsport
posted on 24/12/08 at 01:24 PM Reply With Quote
the only problem is you get a lip on the end .
either cut and roll , or use a pipe expander . its great for swaging upto a size tho .
nice and simple tool i see - just need a foot operated pedal and about 50 more tons and youve cracked it !
John Bonnett
posted on 24/12/08 at 02:28 PM Reply With Quote
Paul, you are an artist in metal. How did you get the die out of the tube once it had been formed?
atb
John
907
posted on 24/12/08 at 03:01 PM Reply With Quote
Hi VS
Your right about the lip. That was the last thing I was expecting.
Mk1 former was 51 o/d. A bit sloppy.
Mk2 is a wee bit smaller so the edge of the pipe is a dead 50.8mm (2"
I then case hardened it hence the former is blue.
Where these are going it doesn't have to be a perfect fit.
With a 300mph wind passing them you won't detect a bit of blow.
To answer your point John the former fell out of the pipe at about the same speed as my bottom jaw dropped.
As for the artist bit... I will be by about 10 o'clock tonight.
Paul G
thunderace
posted on 24/12/08 at 04:49 PM Reply With Quote
looks great
A versatile tool.
Paul G
