Author: Subject: can i turn a grinder into a polisher
thunderace
posted on 24/12/08 at 06:08 PM Reply With Quote
i was hoping i could get somthing like this to put on my grinder that looks like item 2
http://cgi.ebay.co.uk/POLISHING-ADAPTER-FOR-DRILL-MOP-PIGS-TAIL_W0QQitemZ310110868223QQcmdZViewItemQQptZUK_BOI_Metalworking_Milling_Welding_Metalworki ng_Supplies_ET?hash=item310110868223&_trksid=p3286.c0.m14&_trkparms=66%3A2%7C65%3A15%7C39%3A1%7C240%3A1318
im looking on how to do this to my grinder
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=270319947961&ssPageName=MERC_VI_RCRX_Pr12_PcY_BIN_Stores_IT&refitem=280296620448& itemcount=12&refwidgetloc=active_view_item&usedrule1=CrossSell_LogicX&refwidgettype=cross_promot_widget&_trksid=p284.m184&_trkparm s=algo%3DCRX%26its%3DS%252BI%252BSS%26itu%3DISS%252BUCI%252BSI%26otn%3D12
tomgregory2000
posted on 24/12/08 at 06:09 PM Reply With Quote
NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO
the grinder spins toooooo fast and will just burn the surface
thunderace
posted on 24/12/08 at 06:15 PM Reply With Quote
ok ok ok ok ok gooooooooooooooood
i take it it is a no then i seen a grinder thats also a p[olisher on ebay item number 280296199604
austin man
posted on 24/12/08 at 06:29 PM Reply With Quote
I had a grinder with variable speed which I used on the lowest setting for polishing/ buffing paintwork with no problems
dhutch
posted on 24/12/08 at 06:55 PM Reply With Quote
Ive used a simular item as in the OP to fitt a buffing mop to a bench grider for cleaning up brass. But i would agree that for polishing paint, unless its a decent variable speed job, an angle grinder would be to fast.
Often though about using a orbital sander....
Daniel
mr henderson
Depends on what you plan to polish. No good for paintwork, but if you are polishing metal then it would be OK
John
posted on 24/12/08 at 07:19 PM Reply With Quote
A dual action sander is a good alternative. You can get them cheap from Aldi sometimes then buy a head like this for it.
thunderace
posted on 24/12/08 at 08:32 PM Reply With Quote
SORRY I JUST WORKED OUT YOU ON ABOUT THE OTHERE TYPE OF GRINDE NOT THE TWIN WHEEL TYPE
IM LOOKING A A METAL POLISHER WITH MOPS AND SOAP FOR ALLOY AND STAINLESS.
[Edited on 24/12/08 by thunderace]
mad-butcher
posted on 24/12/08 at 08:43 PM Reply With Quote
This is defo place for paintwork polishing saved me a fortune by not buying the wrong equipment
Detailing world dual action polisher
mad-butcher
posted on 24/12/08 at 08:45 PM Reply With Quote
I'm sure that's all they are anyway
