YQUSTA
| posted on 18/1/09 at 09:38 PM |
Hole saws
Just wondered if any one has bought or used these HOLE SAWS?
All I will be using them for is cutting the holes for my switches.
The dash is carbon if that makes any difference.
All opinions welcome
YQUSTA
daniel mason
| posted on 18/1/09 at 09:54 PM |
holesaws
not used these exact ones but have used the downlight holeaws at the bottom of the page on your link.They are fine
Steve Hignett
Do a search on here for Hole Saws and you will see other people's opinions!
I would just get Starret Hole Saw's from ebay if I were you - they will be dearer, but you will hav them forever (or a very long time as long as
you look after them), if you just buy the sizes you need it won't cost millions...
Sorry if it wasn't the answer you wanted.
adithorp
I cut mine with them. Shouldn't be a problem.
adrian
http://jpsc.org.uk/forum/
LBMEFM
| posted on 18/1/09 at 10:04 PM |
If you are only doing the dash then no probs, I used simular, why buy good quality long life one's for a one off use.
Mask off the area with tape, slow drill speed and make sure the dash is firmly clamped down.
martyn_16v
| posted on 19/1/09 at 12:11 AM |
step drills rock, it's one of my favourite tools
I had an identical set of holesaws at work. On the plus side they lasted for several years, until they got nicked out of my van. Much better than the
really flimsy split types. However the hardest thing they ever got used on was MDF, and even that wasn't much fun, they'd burn through
rather than cut.
I'm slowly building up a set of nice Bosch progressor saws now, they're world apart tbh
GeoffT
| posted on 19/1/09 at 12:32 AM |
I recently used one of these :-
erbauer holesaws
.....which cut through a piece of 6mm steel plate with no problem, much to my surprise
YQUSTA
| posted on 19/1/09 at 08:07 AM |
Thanks for all the replys.
The reason I need the set is for the 22mm and 32mm (for the large start switch)
They are just for doing the dash so I think i'll give them a shot.
YQUSTA
| posted on 19/1/09 at 10:44 AM |
They'll definitely be fine for CF....
