Author: Subject: Brake pipe joint sealing compound
r1_pete
posted on 26/1/09 at 02:58 PM Reply With Quote
Has anyone used THIS STUFF from Frost's, is it any good / worth using? looks like a good product, but so did POR15 and I got nowhere with that.
Cheers.
Pete
prawnabie
posted on 26/1/09 at 03:14 PM Reply With Quote
Id have thought that if you needed that, then there is something wrong that needs to be fixed!!!
Mr Whippy
posted on 26/1/09 at 03:23 PM Reply With Quote
can't see the point in it tbh they seem to be suggesting using it on the thread but as its the flange that’s normally sealing the pipe it makes no sense at all to use that product. Don't like it one bit, use it on house radiators only as it could hide for a while a connection that hasn't been made up correcty.
[Edited on 26/1/09 by Mr Whippy]
r1_pete
posted on 26/1/09 at 03:35 PM Reply With Quote
Your right, the mechanical seal should be enough, never had a leaker yet, so I'll keep my tenner in my pocket....
mangogrooveworkshop
posted on 26/1/09 at 03:47 PM Reply With Quote
Thats just a pot of snake oil.....keep the ten quid in your pocket.
If your brake system leaks its like telling you to tighten up the joint.....that stuff could mask a poor joint.
mookaloid
posted on 26/1/09 at 04:02 PM Reply With Quote
Definite no no as far as I can see.
Alan B
posted on 26/1/09 at 05:19 PM Reply With Quote
Agreed...pointless, useless product.
ONLY tapered threads are meant to seal on the threads. Parallel threads always seal another way..in this case metal to metal at the flare/fitting interface.
I suspect they may mean it's for tapered threads, but the the picture they showed is clearly wrong and very misleading.
[Edited on 26/1/09 by Alan B]
Johneturbo
posted on 26/1/09 at 07:27 PM Reply With Quote
My wilwoods seal on the taper but i used PTFE tape. £175 from screwfix
i did think about using it on the other joints, but it shouldn't be needed really
mad4x4
posted on 27/1/09 at 07:36 AM Reply With Quote
Thats a bit dear for PTFR tape. I'll go to B&Q for mine..
On another note in the Oil industry PTFE tape is banned/not used on a lot of systems cause it breaks down and causes blockages in the PIPES. Most Hyrdaulic Compainies will sell SWAK or a Locktite Version.
Linky
Scot's do it better in Kilts.
