andrew-theasby
| posted on 31/1/09 at 07:55 PM |
Where can i get these studs from?
Hi, can anybody suggest where i can buy some of these studs from? We use them at work all the time but dont have many different sizes
jacko
| posted on 31/1/09 at 08:25 PM |
HI Andrew how are you keeping?
The only place i can think of is F R Scotts in Hull
i don't know if they have them but it may be worth a phone call
Graham
tycho
| posted on 1/2/09 at 05:20 PM |
They look a bit like Hi-Lok fasteners used in aircraft, but I don't think they are available with a metric thread.
andrew-theasby
| posted on 1/2/09 at 11:19 PM |
ye, exactly the same as hi-loks, theyd do too, but i dont suppose you can buy them off the shelf, any sort of blind bolt/stud will be fine
vinnievector
| posted on 2/2/09 at 05:00 PM |
Hi
AS the guys say it looks like a hi lock.
Tools to fit these are hi lock dipper to measure lengh reamers as they start from 5 /32 nom 1st 2nd oversize and up to1inch dia loads of different
collars alu ,steel nom 1st second over and the come in tension shear, steel and titanium.
cant think why you would want to fit them
andrew-theasby
| posted on 8/2/09 at 08:59 PM |
Yep, know all about them, use them all the time. guess nobody knows where i can buy them from then?
kipper
| posted on 9/2/09 at 12:48 AM |
Hi try mark at Rileys in Selby. He suplys the power stations with specials and is very helpful.
Kipper.
Where did that go?
andrew-theasby
| posted on 9/2/09 at 11:42 AM |
ok, i just expected them to do standard stuff going by thhe size of the shop! Thanks
