dan__wright
posted on 1/2/09 at 05:27 PM |
geometry setup: tools
im looking at buying tools to allow me to setup suspension.
the two bits in not sure about at the mo:
camber / castor / kpi:
http://cgi.ebay.co.uk/Sealey-GA450-Magnetic-Camber-Caster-Kingpin-Gauge_W0QQitemZ400023715235QQcmdZViewItemQQptZUK_Hand_Tools_Equipment?hash=item40002
3715235&_trksid=p3286.c0.m14&_trkparms=72%3A1683%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
or
http://cgi.ebay.co.uk/AccuLevel-Digital-Caster-Camber-Gauge-RACE-RALLY-Kitcar_W0QQitemZ250310431749QQcmdZViewItemQQptZUK_Measuring_Tools_Levels?hash=i
tem250310431749&_trksid=p3286.c0.m14&_trkparms=72%3A1683%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
is there a need for this (otherwise i have to use them on hub or disk or get an adaptor?)
http://cgi.ebay.co.uk/Caster-Camber-Gauge-Adapter-Tool-RACE-RALLY-KIT-CAR-wrc_W0QQitemZ300260065631QQcmdZViewItemQQptZUK_Measuring_Tools_Levels?hash=i
tem300260065631&_trksid=p3286.c0.m14&_trkparms=72%3A1683%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
tracking:
string method? maybe make brackets up on the car to allow me to attach bars to so there's no messing about with axle stands?
corner weights:
any cheap methods?
dont want to spend more then necessary, if what ive listed looks rubbish then let me know what i should be looking at
FREE THE ROADSTER ONE…!!
ashg
posted on 1/2/09 at 05:39 PM |
like the look of the second one.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
v8kid
posted on 1/2/09 at 05:58 PM |
Regarding corner weights you can make your own, search on Ruggles Scales for inspiration. ! have a set I made and they have given stirling service for
years with repeatable results.
Remember you need a level floor to take any measurements fom there is a very informative video on you tube but it is an involved process.
PS I should have mentioned you can download a nifty programme to convery your iphone into a digital spirit level accurate to 0.1 degree.
[Edited on 1-2-09 by v8kid]
mad-butcher
posted on 1/2/09 at 06:15 PM |
8 sets scales from tesco @ £3.50
v8kid
posted on 1/2/09 at 06:21 PM |
Absolutely brilliant!
Remember if the scales are not level with respect to each other the readings will be inaccurate. Most flat floors are accurate to less than a mm over
thier whole lengrh
mark chandler
posted on 1/2/09 at 07:47 PM |
4 scales were all I needed for my bec, they may not be the most accurate so I zero'd with a heavy weights on them before I started. Accurate
enough to register 5kg change in corner weights if I lent forward in the seat !!!
For camber & caster and tracking all you need is a plumb line and laser level and a bit of time, have a search on here plenty of advise.
Basically a straight edge that spans wheel rim to wheel rim and hold something like this against it for camber
link, for caster straight line between
upper and lower ball joints, hold its against again.
For tracking hold a lazer spirit level against the straight edge and point at a board infront of your car.
Regards Mark
v8kid
posted on 1/2/09 at 08:33 PM |
Mark,
Great tip I think I'll try that it should make it more accurate as you say by zeroing with a heavy weight.
Trouble is what are you measuring?
Suppose your floor was a quarter inch out on the diagonal front to back? One wheel will be a quarter inch lower or higher tyhan the others.
With 300lb springs thats 75lb out before you start!
You can have the most accurate scales in the world and the results will still be, sorry, but they will be rubbish.
Whats more the "self levelling" scales are no such thing when you read the sales blurb closely.
The secret is an accurate level before you start - and it's a pain to do.
Fred W B
posted on 2/2/09 at 08:20 AM |
Agreed, but it could be argued that having the front and rear set of scales exactly on the same plane is not as important as getting each wheel pair
horizontal.
That can be checked by putting a straight edge across the scales with a spirit level on top, and corrected by adding shims of steel or hardboard etc
on top of the scales.
Mark the scales positions on the floor and the shims once set up and redoing it in future will be easy.
Remember to check the tyre pressures before starting to record weights.
I stand on the scale holding a toolbox
Fred W B
[Edited on 2/2/09 by Fred W B]
posted on 2/2/09 at 10:55 AM |
quote: Originally posted by v8kidSuppose your floor was a quarter inch out on the diagonal front to back? One wheel will be a quarter inch
lower or higher than the others.
Would that be true if your springs were only an inch long ?
