24vseven
posted on 6/2/09 at 06:30 PM |
compressor
hi folks any advice on what size comp to get the one i have is crap and has packed up
i only want one for a single workshop 240v mains not to big it fills the place but not one that runs out of puff every 2 mins whan useind a die
grinder ect
thanks
COREdevelopments
posted on 6/2/09 at 06:38 PM |
to run a die grinder or any air powered tools i would go for at least a 100l tank, i have a small 50l 3hp compressor it cant really cope with my
1/2" impact gun, not really enough pressure there. depends how much space and money you got.
rob
posted on 6/2/09 at 06:40 PM |
Die grinders and cut off saws will make anything grunt, they use a lot of cfm. I have a 3hp 12cfm unit and don't use the die grinder because it
runs the motor all the time. They ice up in this weather as well so now I use a dremel lookalike, it uses less electricity than a compressor.
24vseven
posted on 6/2/09 at 06:44 PM |
i need it to be up to runninig all my tools air ratchet impact gun grinder
posted on 6/2/09 at 06:49 PM |
You want to be looking for one with at least 14 cfm, larger tank the better. Also check the bore size of your air line , small bore/longer pipes will
restrict air flow. I make it a point to use 10mm airline
[Edited on 6/2/09 by rusty nuts]
LBMEFM
posted on 6/2/09 at 09:01 PM |
Anything but Clarkes
