tomprescott
| posted on 25/2/09 at 07:00 PM |
Paint!
Howdy folks!
Hoping that one of you genii can enlighten me to paint. Looking to respray a golf I bought recently on the cheap, I'm very steady handed and
always make a good job when spraying with a can, plus I have access to a large air compressor and a load of spraying equipment. The thing is, I
don't know much about the paint itself, as far as I'm aware there are two main types - acrylic and cellulose - what I'd like to know
is - are there any differences/difficulties/pros and cons between each paint medium, what extras do I need (i.e. hardeners etc.) and which am I likely
to be most successful with (on a tight budget)? P.S. I'm gonna go for a jet black gloss finish. Cheers in advance!
Tom
Paul TigerB6
| posted on 25/2/09 at 07:14 PM |
ever heard of two-pack paint??
tomprescott
| posted on 25/2/09 at 07:15 PM |
Nope, what is it?
minitici
| posted on 25/2/09 at 07:45 PM |
quote: Originally posted by tomprescott
Nope, what is it?
It does what is says on the cans - "Kills You!
So remember the PPE when using....
flak monkey
| posted on 25/2/09 at 07:55 PM |
Cellulose is the easiest to spray IMO and any decent automotive paint supplier will sell it to you as long as its not for commercial use.
Proper 2 pack paints are dangerous and need proper respiratory gear as they contain some pretty nasty stuff aparently.
Sera
http://www.motosera.com
Paul TigerB6
| posted on 25/2/09 at 08:10 PM |
Isocyanate's - related to cyanide. Its what the automotive industry have used for years but have now moved over to water based paints. Ideally
you want an air fed mask and a spray booth for this - does your spray equipment extend to a booth?? Where are you going to spray??
As Flak says, cellulose will be the easiest to spray (and may give you lots of flatting practice).
tomprescott
| posted on 25/2/09 at 09:09 PM |
I've got access to a completely empty and very clean double garage for a few days, It doesn't have mask ventilation but There's a
small window I'll crack for ventilation. I think I'll steer clear of the two-pack, I'm not a fan of following safety precautions!
Cellulose looks like a plan, I've seen a complete kit on ebay, from Jawel Paint supplies for £150, is this a reasonable price?
| posted on 26/2/09 at 03:46 PM |
If it includes the compressor and gun it is Sorry, I'm a bit spoilt as we have a local supplier who still sells cellulose paint and thinners
and if I just went in and bought what I need it would be about half of that amount. I always have gobbo and production paper lying round in the shed
from other jobs and if it's convenience you are after then that is a reasonable price. Cellulose is a good choice as you can do a lot more to
rectify your mistakes and as for the steady hand, if you are used to arsehole cans you had better practise a bit first or you will have lots to
rectify
