posted on 10/3/09 at 09:00 AM |
buffing up alloy casting - how to
alloy casting in question in crossflow timing cover.
it has a coat of dark grey tranish/oxide that can be sanded off using 400 wet'n'dry but it is quite time consuming.
is there a hosehold chemical that will strip the layer off?
what about grit blasting?
Mr Whippy
posted on 10/3/09 at 09:32 AM |
Me I'd use course wire wool etc and some wd40 to get most of the crap off, then autosol and a soft brass rotary brush, followed by autosol and a
rotary cloth buff on the drill. Once shiny, wash it very well with white sprit, then several coats of lacquer
wilkingj
posted on 10/3/09 at 09:58 AM |
I used buffing mpos and soap bars (Buffing compund)
from Shesto.
Linky
My polisher is based on a scrap Garder Shredder with a 1100Watt motor.
Warning!!!
Wear eyeshields, a dust mask, and leather gloves.
It really does the job.
I have used this to take brushed stainless to a mirror polish finish.
I also started with 800 then 1200 grit wet and dry.
Best Regards
Geoff
http://www.v8viento.co.uk
sucksqueezebangblow
posted on 10/3/09 at 10:16 AM |
Battery Acid will have it off in no time, but watch it, it is quite agressive so a minute or two at most before you rinse it and check progress. You
can get battery acid from motor factors for a couple of quid. I did my steering column bearing bracket with it and it came up beutifully in a couple
of minutes. The finish is a uniform silver/grey of course. To improve on that you would need to buff it with a polishing wheel.
[Edited on 10/3/09 by sucksqueezebangblow]
thunderace
posted on 10/3/09 at 10:34 AM |
one tip alloy will not go shiny is its very cold i love polishing things.
posted on 10/3/09 at 10:37 AM |
LOL - I am not after mirror finish.
The acid idea sounds good - wold vinegar be effective?
There is raised casting of Fford logo plus some numbers that is hard to get to with wet'n'dry. I could grind that off but .....
Mr Whippy
posted on 10/3/09 at 10:53 AM |
Vinegar will take it all off but leave a very mat surface, perfect if you want to then spray it. I use vinegar to clean carbs but you need to
occasionally scrub them with a paint brush otherwise they get very minging. With a bit of work they’ll look like new.
Thunderace, I have 8 rims that you very welcome to polish up like those
UncleFista
posted on 10/3/09 at 11:22 AM |
What about "Wonder Wheels" alloy wheel cleaner ?
I know it's acid based and you have to rinse it off after a few minutes, might be worth a try if you already have some ?
Tony Bond / UncleFista
