blakep82
| posted on 14/3/09 at 02:32 PM |
sika flex?
i went to get some sika flex, someone said you get it from B&Q, which it about 40mins drive drom here. is this the right stuff? i couldn't
find anything that said sika flex on it
  sika
also someone on here said i can use it to stick my trigger wheel to the front pully oin the car. is this true, or was he taking the wee?
________________________
| posted on 14/3/09 at 02:45 PM |
Wouldn't like to have my trigger wheel come off the pulley at 7,000 RPM ! I made sure mine was well secured. Can't help with the stuff you
have but would suggest asking your local car paint suppliers , they are likely to stock proper Sikaflex. Got my last tube from Unipart
blakep82
| posted on 14/3/09 at 02:48 PM |
well, i wouldn't like it coming off either! thats why i wasn't sure.
can't think of any paint suppliers round here
big_wasa
| posted on 14/3/09 at 03:06 PM |
A good Pu from any paint or car spares place.
I would in no way use it as the only faster for the trigger wheel
When dry it has some give like rubber not hard like epoxy.
blakep82
| posted on 14/3/09 at 03:13 PM |
ok, so i can get it from a car paint place, but what about the stuff i've got?
Mal
| posted on 14/3/09 at 03:15 PM |
The grade of Sikaflex normally used for bonding panels is 221.
blakep82
| posted on 14/3/09 at 03:30 PM |
quote: Originally posted by robocog
Can't help you with the Sikaflex...
I certainly wouldn't want a ninja death star popping through the nosecone
Trigger wheel definately needs the minimum of a bolt through it as it would make a fair exit hole before potentially making an equally impressive
entry hole in someone or something
I would only use PU on stuff that when it falls off is not likely to kill anyone
Regards
Rob
mines definitely getting welded then
Guinness
| posted on 14/3/09 at 03:35 PM |
Give the boys at MAC1 a ring re the sikaflex.
I phoned them on a Thursday afternoon, and the tubes arrived on a Friday morning!
Top product, top service.
Mike
wicket
| posted on 14/3/09 at 03:57 PM |
Here's the data sheet for AT Universal
http://ukconstr01.webdms.sika.com/fileshow.do?id=542
and for 221
http://www.sika.co.uk/1-comp_poly_tech-2.pdf
blakep82
| posted on 14/3/09 at 04:12 PM |
and for 221
I'm only using to stick some perspex round here
and then the outer body panels fit on over that
and then door covers over that
its only really to stop things (money, house keys, body parts ) falling out the sides since the sills on the body work doesn't go all the way
under the car
so looking at the data sheets, i think sikabond at will do the job well. it seems to have the same properties, and as far as i can tell, is almost
identical for what i need it to do. i'm not using it to stick any panels on which will be subject to a battering from wind or anything like cycle
wings for example.
at universal seems ideally suited to flooring, but still has the same elasticity and sticking properties
[Edited on 14/3/09 by blakep82]
rb968
| posted on 14/3/09 at 05:36 PM |
If you are looking for Sikaflex 221 I noticed it in these guys catalogue.
http://www.merlinmotorsport.co.uk/advanced_search_result.php?keywords=sikaflex
Rich
dhutch
| posted on 14/3/09 at 05:56 PM |
The stuff you have there is clearly made by sika, and is
an adheasive/sealer but from the datasheets above it doesnt apprear to be polyuerthene (PU) based.
- However, whether is does the job as well is upto somone else!
Daniel
mr henderson
| posted on 14/3/09 at 06:41 PM |
A trigger wheel is going to be spinning about itself, and won't have enough potential energy to do any real harm. If it was really heavy maybe,
but even then it wouldn't go very far, probably just drop off and land in the road.
John
omega 24 v6
| posted on 14/3/09 at 06:46 PM |
Looks like this stuff.
on the left page 10 i think
Or this which it says is PU hybrid high strength sealer/adhesive
[url=http://www.sika.co.uk/uk-home/uk-con/uk_construction-builders-merchants/uk_construction-adhesives-sealant-fillers.htm]Fifth one down
Most SIKA sealer /adhesive stuff sticks like poo to a blanket I'm sure this will be fine. try it on a bit of scrap first and see.
[Edited on 14/3/09 by omega 24 v6]
blakep82
| posted on 14/3/09 at 07:32 PM |
^ looks like a 'new improved' sika flex then?
i don't know..
having looked at the data sheets, i think its more than up to the job since its only 1/4 the price of the stuff from Merlin i'm going to
use it
Canada EH!
| posted on 14/3/09 at 09:03 PM |
Being as your on an Island, try your local marine dealer for Sikaflex.
| posted on 15/3/09 at 12:34 AM |
Dream on. Anything letting go at even 3,000 RPM can cause an awful lot of damage/injury I have seen fan blades exit a bonnet before and it's
scary whet damage they can do . A trigger wheel coming loose after being put on with Sikaflex will come loose from one point on its circumference and
fly off at a tangent . I for one would not like to be in the firing line!
John
mr henderson
| posted on 15/3/09 at 08:23 AM |
John
How much does this trigger wheel weigh, then?
I daresay standing in its path would not be a good idea, but that's a hell of a far cry from it bursting through a bonnet and then seriously
damaging a bystander, which is the scenario described earlier.
In any case, the comparison with a fan blade is seriously flawed, as each blade is laready some distance from the centre of rotation, a vital
component of the centripetal force, whereas, as I said earlier, the trigger wheel would be spinning around its own centre.
HTH
John
