Author: Subject: eninge mounts mk III
posted on 24/3/09 at 09:32 AM Reply With Quote
.... or do away with the recently pruchased engine mounts and fit land rover ones, like these.
then make a box at 45 degree from the top to the engine, much in the style of the haynes roadster book?
would that be better option?
^^^ those a series Land Rover moutns - anyone know if the one in photo are fro front or rear of engine, as well as size (diameter/thickness/stud thread)?
taq.
handyandy
posted on 24/3/09 at 09:35 AM Reply With Quote
i would prefer this method as it would be less stresses on the metal that you would fabricate,
IMO of course, but as i,m building a roadster maybe i,m biased towards this method
andy
iank
posted on 24/3/09 at 09:45 AM Reply With Quote
Those mounts are these I think
http://cgi.ebay.co.uk/Land-Rover-Defender-V8-Engine-Mount-Mounting-Rubbers_W0QQitemZ250376113124
Equivalent to land Rover Part numbers: ANR1808, STC434, NRC9560, NTC5900, RTC6115, ANR2471
The measurements of these mounts are:
Thickness/height: 37mm
Diameter: 77mm
Studs: M10 x 20mm Male both sides
Very cheap!
Anonymous
l0rd
posted on 24/3/09 at 09:51 AM Reply With Quote
Yes they are these one. Exactly the ones I got as well.
dhutch
posted on 24/3/09 at 01:54 PM Reply With Quote
With the interleaf, you will get less axial deflection too, with limited change in axial shear, which is proberbly a good thing.
(that is about the sum total of my knowlage of mounts gone)
Need a pair myself.
Daniel
dhutch
posted on 25/3/09 at 10:36 AM Reply With Quote
Originally posted by dhutch
With the interleaf, for the same sure hardness of rubber you will get less axial stiffness/deflection, with limited change in axial stiffness/shear, which is proberbly a good thing. (engine bobs up and down less, but can still rotate around CofG in simular way.
- That is about the sum total of my knowlage of mounts gone.
Need a pair myself.
Daniel
flak monkey
posted on 25/3/09 at 09:29 PM Reply With Quote
I use those mounts too.
Rock solid and cheap as chips
Sera
http://www.motosera.com
owelly
posted on 25/3/09 at 10:07 PM Reply With Quote
Rather strangely, my local factors had the LR engine mounts listed for £8 each but gearbox mountings for £4.50 each. They're exactly the same!!!
http://www.ppcmag.co.uk
posted on 25/3/09 at 10:28 PM Reply With Quote
Which did you buy then ?
