Author: Subject: bending exhaust manifold?
posted on 25/3/09 at 11:20 AM Reply With Quote
let's say I have a mild steel 4-2-1 exhaust manifold that turns horizontally through 90 degree so the single pipe exits through the body work.
If I wanted to lower the exist point, how could I do this?
(the fallback solution would be to enlarge the hole in the panels upwards)
blakep82
posted on 25/3/09 at 11:22 AM Reply With Quote
cut and weld in a new section of tube? even if it will only be like an inch...
or enlarge the hole, and cover it with a nice piece of polished ali or stainless steel, with the correct size and position hole, and it covers the enlarged one behind?
[Edited on 25/3/09 by blakep82]
________________________
Dangle_kt
posted on 25/3/09 at 11:48 AM Reply With Quote
I looked into it as my westfield manifold didn't quite work on my locost, but every tube bender I tried said they wouldn;t bend a tube that had already been bent.
In the end I got the help of a couple of very kind souls off here who sorted it for me by cut n shut!
posted on 25/3/09 at 11:50 AM Reply With Quote
^^^ interesting - my initial reaction would be to attempt to heat it up then try to twist it a bit - I would be looking to move the end down by 30 mm max.
MikeCapon
posted on 25/3/09 at 12:17 PM Reply With Quote
What about sand bending it?
iank
posted on 25/3/09 at 01:07 PM Reply With Quote
Should be possible with lots of heat. NS Dev bent his roll cage using a big burner and a simple pipe bender, can't imagine the exhaust manifold is made of thicker steel.
http://www.locostbuilders.co.uk/viewthread.php?tid=59476
[Edited on 25/3/09 by iank]
Anonymous
