Gary 7
| posted on 7/4/09 at 08:06 PM |
compresser drain tap
I picked up a small 6 litre compresser yesterday,all works fine,but the drain tap on the tank has had it. Anyone know were i can get one from.
westf27
| posted on 7/4/09 at 08:24 PM |
put a bolt in it ?
555
dave r
| posted on 7/4/09 at 08:38 PM |
auto drain or manualmatitic
guess its possible 1/8 or 1/4 in gas tap, if manual, rs, or any pnuematic supplies places will have one quite cheap
austin man
| posted on 7/4/09 at 10:21 PM |
bolt with an o ring should do it ideally brass though due to rusting
| posted on 8/4/09 at 06:58 AM |
Might have a spare one in the shed
| posted on 8/4/09 at 07:02 AM |
Sorry I just checked it has already been removed -- the hole looks like standard pipe thread - 1/4 BSP
| posted on 8/4/09 at 07:24 AM |
fit the correct bolt - don';t be tempeted to bodege with something that does not fit and ptfe tape or somat - once you have the tank up to
pressue, a loose bolt may shoot out like a bullet!!
| posted on 8/4/09 at 08:55 AM |
You want a drain cock, I need one for mine but I'm too idle to fit it I just use the pliers to tighten the one that's in it to stop it
from hissing. There's a compressor shop near us and they have them in brass to the correct rating.
