johnemms
| posted on 13/4/09 at 05:19 PM |
Impact wrench - comments please
Hi all .. in fancy an impact wrench for general stuff around the garage n driveway.. any reason why i should'nt buy
this..link here
cheers...
mr henderson
| posted on 13/4/09 at 05:32 PM |
Looks good to me. Machine Mart have got a no VAT thing on at the moment too. Let us know how you get on with it, I might get one too. I've got a
Makita 12v cordless that I use all the time, (I've got 1/4, 3/8 and 1/2" adaptors), but the MM unit looks good for bigger stuff
John
jacko
| posted on 13/4/09 at 05:59 PM |
Expensive but very very good
Snap-on
| posted on 13/4/09 at 06:44 PM |
Go for a cordless wrench --- B&Q sell a 1/2" square drive 14.4v MacAllister I have been using one for about 8 months now and never use
anything else, it is small enough to get into very tight awkward spaces
| posted on 13/4/09 at 06:45 PM |
Wouldn't bother with the Clarke wrench , spend a bit extra and get a decent one. I second the Snap On item, have had one for the last 3 years
thats used everyday and still going strong. Has loads more torque than every other wrench I've had.
mr henderson
| posted on 13/4/09 at 07:29 PM |
How much did it cost? Cost is always an issue here. If it cost a lot more then I would expect it to be a lot better, but maybe the guy doesn't
need to use it a lot?
John
thunderace
| posted on 13/4/09 at 07:45 PM |
thats a very good one Max. torque 450Nm for the price.
loads of power.
1000 Watt, 230V motor
Max. torque 450Nm
No load speed 2200rpm
No load impact rate 3400ipm
Drives bolts up to a max size of M12
Bit holder size ½" square drive
Includes socket sizes 17, 19, 21 & 22mm and carry case
40inches
| posted on 13/4/09 at 09:22 PM |
Be VERY careful of powerful impact wrenches
http://uk.truveo.com/impact-wrench/id/3613662346
| posted on 14/4/09 at 07:01 AM |
Bigger isn't always best --- buy a wrench suitable for the jobs where it will be of most use.
novacaine
| posted on 14/4/09 at 07:36 PM |
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but
your older, shorter of breath and one day closer to death
speedyxjs
| posted on 11/9/09 at 08:56 AM |
x2
andrew-theasby
| posted on 19/9/09 at 11:34 PM |
Are the 240v ones any different in size to the 24v cordless ones?
